Old 04-28-2019, 05:32 PM   #41
primo20's Avatar
Originally Posted by Iwannacamp View Post
[emoji106][emoji106][emoji108][emoji108] PM me one of those babies over!!
here you are mister!
ID:	203080   Click image for larger version
ID:	203081   Click image for larger version
2023 Rockwood 2911BS | 2023 Silverado 3500 SRW Duramax
primo20 is offline   Reply With Quote
Old 04-28-2019, 05:50 PM   #42
dbledan's Avatar
That looks good!
dbledan is offline   Reply With Quote
Old 04-28-2019, 06:52 PM   #43
Iwannacamp's Avatar
Originally Posted by dbledan View Post
You are correct. Pellets are processed sawdust. Even the bagged chips and chunks should be fine.
I was primarily talking about stick burners for the BBQ purists for the wood transportation problem.
10-4.
2017 Puma 297RLSS
Old 04-28-2019, 06:55 PM   #44
Iwannacamp's Avatar
Anyone use a smoker?
Well. Looks like I’m smokin some burgs next week!! [emoji108]
FWIW the boys that ain’t never tried them are missing it.
Blasphemy here....way better than the Blackstone burgers. Yes I said it.
2017 Puma 297RLSS
Old 04-28-2019, 07:01 PM   #45
I had a Traeger portable...it sucked. Put it at 185 and it would go to 300. Apparently, Traegers are famous for that. Took it back to Costco for a full refund and bought a Rec Tec. Night and day difference.
babock is offline   Reply With Quote
Old 04-28-2019, 07:07 PM   #46
BandJCarm's Avatar
Rec Tec is awesome. I have the portable. They don't make it anymore. Still, it was too heavy to put in trailer basement, so I got GMG and leave Rec Tec at home. It's way more sturdy, but heavy.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 04-28-2019, 07:14 PM   #47
I started on uds and still use them occasionally. The drums do amazing ribs. I had an early(one of the first) traegars and had trouble in the winter. Many of my neighbors have newer ones and love them.
My go to at home is the big green egg but I don’t transport it. It is amazing and I can load it up at 4am, set the temp and then let it run all day
I have thought about a smoky joe for rev park but I am a little concerned about the smoke
'15 Salem 28 RLDS
'17 Ram 1500 ED airride
Predator 3500
H20loo is offline   Reply With Quote
Old 04-28-2019, 07:19 PM   #48
I came back this afternoon hoping I had a few responses. Wow. I've never had so many answers to a post before. Everyone likes to cook, don't they.
Thanks everyone. There are some eye opening comments and I've learned of a couple of smokers I didn't know about before. A few stand out for me and I'll be checking them out further.
gastan is offline   Reply With Quote
Old 04-28-2019, 07:29 PM   #49
I have the trailblazer RT-340. Has foldable legs. I haven't brought it camping yet but a 1000 times better than the Traeger.
Old 04-28-2019, 07:33 PM   #50
BandJCarm's Avatar
Yes, way better. I don't even know my model number. Service was awesome when I got it. They even gave me a new one when my paint peeled!!!
My legs fold, but it's just too heavy to get into and out of the truck or RV. I also bent it a little in a campground when I jacknifed and it was in truck bed. But it works, at home, and the GMG stays in the camper.
Just no need for any other grill/smoker. Only other thing you need is something to fry on, and something to deep fry on.
FROG AR-0019-242
Old 04-28-2019, 07:33 PM   #51
I've got a medium Big Green Egg. I absolutely love cooking with it. Burgers, steaks, ribs, wings, even pecan pie. For travel I just stow it in the basement without issue. I do also have a Weber Q220 (propane) for times there is a fire ban in place.
Trilogy 38RE
-lenny- is offline   Reply With Quote
Old 04-28-2019, 08:05 PM   #52
I use a pit boss vertical pellet smoker that is electric.. my 5ver is not set up for boondocking so I have a pit boss tailgater model that is pellet and electric as well
Jeff from Burlington Ont is offline   Reply With Quote
Old 04-28-2019, 11:32 PM   #53
I've been using the little Brinkman charcoal smokers for more than 30 years. Last time I checked they cost around 45-50 dollars. I have a "killer" recipe for smoked turkey that our camping families always ask for around Thanksgiving. They last about 10-12 years before you have to buy a new one, unless you live somewhere that rust never happens.
They are easy to assemble and use, have two racks above the coals, and a water pan to keep the temperature down.
I always use wood chunks, not chips that fall through the charcoal grating. I always soak the wood in a combination of water and cheap red wine overnight before beginning to smoke.
Assemble the smoker, place the big pan at the bottom to catch embers, then the charcoal grill, then above that the water pan and one of the two food grates, then the top grate. Replenish the coals about every 2 hours, and add wood for smoke as you like. Make sure the water pan does not run dry. You can add water and charcoal into the smoker from the side door.
The unit can easily be dis-assembled and loaded into the truck bed of our tow vehicle without interfering with the Cardinal fifth-wheel being towed.
Send me a private message if you want a copy of my award-winning recipe for smoked turkey.
Jakieboy is offline   Reply With Quote
Old 04-28-2019, 11:33 PM   #54
amblt's Avatar
All about smokers
Originally Posted by gastan View Post
I've been thinking of getting a smoker that is portable enough to take with on camping trips. Does anyone use one?
Upright? Barrel? Electric? Propane? Wood chip? Pellet? Charcoal? Any suggestions - or is it a bad idea?
Go to www.amazingribs.com and get all the info you could ever want.
Cheers
amblt is offline   Reply With Quote
Old 04-28-2019, 11:59 PM   #55
I'll take you up on that!
Trilogy 38RE
Old 04-29-2019, 05:19 AM   #56
Frog-Toberfest Organizer
I bought a small charcoal barrel smoker. I clean it after every use and store it in a large tote. I use it at home and on the road.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
Electra glide is offline   Reply With Quote
Old 04-29-2019, 05:35 AM   #57
pellets just dont do it for me flavor wise. charcoal my choice. and a webber kettle indirect set up as smoker
gbaldwin is offline   Reply With Quote
Old 04-29-2019, 05:36 AM   #58
Char-Griller with Firebox. It only goes with us on local trips as it LARGE (can do 20 lbs of featherbones at a time) and either takes up the entire fold down rack on back of TT or goes in bed of truck. Friend will bring his out to our sites if were having lots of people out. It hitches onto the back of his truck and he tow's it. We've done 40 lbs of featherbones, 4 briskets and 2 prime ribs at one time on his.
TheWolfPaq82 is offline   Reply With Quote
Old 04-29-2019, 07:25 AM   #59
satdog01's Avatar
Have the Treager Tailgater with the folding legs which I love, small enough to cook for several people. Also recently bought a smaller version at Costco which is great for two people, can do 8 burgers or a couple of chicken halves. Do potatoes by rubbing olive oil and hitting with course salt wrapped in foil. Takes about an hour, set to 350 and walk away. Home Depot has a neat lid that snaps on to 5 gallon bucket that has a screw insert that is great for storing the pellets in a dry space and easy storage.
2020 Georgetown 31L, Safe T steering, Sumo springs, Onan Geny
2015 GMC Canyon 4X4 TOAD w/Blue Ox tow plates, InvisiBrake
Pepper 🌶 PomChi rescue 545 nights as our camping buddy
Days camped in FR 2011-12 = 77, 13-14 = 98, 15-16 = 129
17 = 81, 18 = 44, 19 = 83, 20= 45, 21 = 76, 22 = 57, 23 = 42
Retired :
satdog01 is offline   Reply With Quote
Old 04-29-2019, 07:54 AM   #60
We have the Traeger PTG (BBQ20) grill and love it. Do note that you need 120V to operate.
2017 Cardinal 3455RL
2017 Ford F-350 XLT 6.7L V8 Diesel 4WD Crew Cab
dtrussell is offline   Reply With Quote
