Forest River Forums
Sunline User Photos
Old 02-21-2010, 02:23 PM   #1
Best Ideas on LP Gas Grills/Burners
When we bought our new Sabre fifth wheel it did not come with one of those hang-on-the-side grills or even a connector for an outside grill. We started thinking about getting a connection installed when a friend, who also bought a new Sabre (different model) that had an external connection, mentioned that his grill had a pressure regulator on it and that, and the fact the external line came after the regulator on the trailer LP tanks, caused a very limited flame at his grill.
What is the best way to hook up an external connection - before or after the regulator? Obviously you must have regulation in the line somewhere, but where is the right spot or do all external grills have built-in regulators?
Also, what are the best thoughts on a gas grill that will serve as an external burner for pots and pans as well as having a (removable) grilling surface?
An electric product will not work for us when dry camping.
poodlepeople is offline   Reply With Quote
Old 02-21-2010, 03:56 PM   #2
NWJeeper's Avatar
Having had lots of portable grills, my latest criteria was for stainless steel as it is easier to keep clean. I prefer the little bottles for their convienience but have bought the adapter that allows you to fill them from a larger tank. I don't have to continuously buy new bottles but instead have 3 of them that I rotate through and fill at home as needed. We also just bought a Cameron's Stovetop Smoker that we can use on top of the grill or at home for smoking our food. We have used it several times and it's the best $50 I have spent in a long time. We love it. Great smoky flavor for our steaks, burgers, sausages, you name it.
Ed & Wendy
www.nwjeepn.com
Old 02-21-2010, 04:47 PM   #3
I added an external connection.It is after regulator I have a Weber Q took regulator off it and installed a 10' hose with quick connect for gas.Grill works fine.
Dave&Eileen
2011 F350DRW 6.7 CC 8'bed
2008 Sierra 295 RLT
bdb2047 is offline   Reply With Quote
Old 02-21-2010, 04:56 PM   #4
Good Idea!
I had not thought about refilling the small bottles. I might still want to do that on the road, however. Is there any problem with overfilling the small bottles from the large LP tanks?
Old 02-21-2010, 06:46 PM   #5
2008Wildcat's Avatar
I use a Coleman Roadtrip grill with the adapter hose to use on my RV tanks.
Love having the interchangeable grills, griddles, and coils for pots/pans.
I don't have a dedicated connection, just unscrew one pigtail from the Rv and use that tank.
Steve and Vicki
2 kids
2006 Dodge CTD
2008 Wildcat 32QBBS
2008Wildcat is offline   Reply With Quote
Old 02-21-2010, 07:00 PM   #6
NWJeeper's Avatar
Not at all, I have filled many of them with the adaptor. The trick is that you have to put the small bottle in the freezer for about 15 minutes first. It's the temperature differential that really allows the bottle to fill fully otherwise you get about a 1/3 to 1/2 full bottle. There are directions with the adaptor for it's use.
Ed & Wendy
www.nwjeepn.com
Old 02-21-2010, 08:15 PM   #7
Since seeing your first response, I have looked at several sites discussing this and all say this is easy, safe, and economical. Some even suggested scrounging for empty small bottles in campground trash bins to avoid even the initial purchase! That may be going too far but I get the picture! Thanks.
There is some dispute on the freezer/refrigerator thing and some others talk about releasing the over-pressure valve to get trapped air out but nothing much else except that the main valve may start to leak after many refills. WD-40 was recommended for that on one site. Oh well, nothing lasts forever.
Another interesting side issue is whether this is legal (crossing state lines with refilled bottles, that is). The consensus seems to be that since no one has ever heard of a highway check point for refilled LP gas bottles, this should not be an issue. Another view is that this is an issue for commercial resale only so I guess setting up a side business in campgrounds doing this may be a bad idea.
Old 02-21-2010, 09:27 PM   #8
NWJeeper's Avatar
Yeah, realistically you can't look at a bottle and tell that it has been refilled. I would think it would be encouraged more. Think of the amount of those bottles out there filling up our landfills. I think those people that are worrying that much about it are just over thinking things.
I would think the intent of the law is that you aren't supposed to buy propane in your state at say $1.69/gal. and transport the containers to the next state and re-sell it where their propane would cost much more due to the state and local taxes there.
I have been refilling mine for over a year now and no problems. Sure is convenient and much cheaper. I just take my 20lb bottle to the farm supply and re-fill it when it runs out and it will keep my little bottles full for the entire year or more. Much cheaper than buying the bottles all the time
Ed & Wendy
www.nwjeepn.com
Old 02-21-2010, 11:18 PM   #9
flyrotor's Avatar
I'm still a huge fan of the Coleman white gas stoves, I have been using two stoves for 7 years now and they have never let me down even once, Usually a pot of coffee brewed on the TT stove (only cause we are not morning people), anything cooked on a griddle is done on the Coleman stoves. My outdoor lanterns are also white gas, they last all week on a small tank of gas. I can easily camp with two stoves and a lantern a whole week on about 1/2 gallon of gas. I don't have any of the multi fuel stoves, but they will burn unleaded which is even cheaper than white gas.
2011 Dodge 2500 CTD, Crew Cab, 169" WB, 6-speed man
2008 FR Wildwood 23 BHLE
Nights camped in 2011:20
Nights camped in 2010: 21
flyrotor is offline   Reply With Quote
Old 02-22-2010, 08:08 AM   #10
Location: Jacksonville Florida - Home of the Jaguars !!!!
I have the "Sidekick grille" that came with my Flagstaff. It does a good job for us, plenty of power/pressure for cooking, and it does hang on the side of the camper, and there is a retractible hose under a cap/cover on the side as well. Easy to set up and use, and the awning overhead is not an issue with heat. The only drawback I see is cleanup after cooking something like Rib-eyes that drip fat. Other than that- Great grille, and you could put a pot on there to cook, I suppose. Randy
'08 V-lite Flagstaff 30WRLS
K&N series 77 intake, Hellwig pro series helper spgs.
'04 Durango Limited Hemi, '72 Mach One 351 cj
copyright 2006 - 2010
Close [X]
