Old 02-19-2019, 10:51 AM   #1
Blackstone Griddle Question?
I have a new 22" Blackstone Griddle. I have the propane line on my 2019 22RR TH & was wondering if there is a hose with the quick connect end and the other end will have a _______ end? If the griddle has a temperature selector is that the high pressure control point? Do I still use the adapter/connector for the 16 oz. bottles? Getting it ready for the season so I'll be "seasoning" the griddle! I'd like to get an eight foot hose if possible? I want to keep the heat away from the laminate siding of the Toy Hauler! Thanks for your opinions & experience!
tomm1947 is offline   Reply With Quote
Old 02-19-2019, 11:17 AM   #2
SailorSam20500's Avatar
There are 2 or 3 other threads going on grills or griddles, Blackstone has been discussed extensively. This site was mentioned a few times. They have 8 and 12 foot versions.
https://propanegear.com/converta-bp-...7-22-griddles/
There may be other suppliers mentioned in those threads.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 03-15-2019, 10:45 AM   #3
Thurman's Avatar
As others I started using the Blackstone with the little bottles and didn't like that. So I bought a stainless steel braided hose so as to put my 20# bottle under the table and the griddle on top of the table. Well, I didn't like that either. I bought the exact hose set-up that SailorSam listed the link to. Soooo much better. No bottle to drag around for one. The only thing that might be negative about the quick hoo-up hose is that I have to get down on one knee to attach the hose to the quick disconnect fitting of the TT. I'm looking for a way to bring that connection up to about waist high.
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
Old 03-15-2019, 02:41 PM   #4
SPRING IS COMING!!!
Tomm1947,
I think this may be what you're looking for:
Blackstone Low Pressure Conversion
Go with the 12' hose... you can always set it closer, but that 8 footer is kinda hard to stretch longer.
BriaBeck is offline   Reply With Quote
Old 03-15-2019, 02:52 PM   #5
swampdonkey772's Avatar
Can a quick connect outlet be placed anywhere on the trailer?
swampdonkey772 is offline   Reply With Quote
Old 03-15-2019, 02:57 PM   #6
SPRING IS COMING!!!
Depending on how handy you are, and your skill level, Yes.
Old 03-15-2019, 03:03 PM   #7
I got that covered. I'm thinking about routing one to the outdoor kitchen then the hose from there to the griddle
black
