Old 06-30-2015, 03:04 PM   #11
Stormrider151's Avatar
We bought something similar called "wompum sticks". I can't remember where we got them but when we tried it we couldn't get the dough to cook right. We may have been using the wrong biscuits. I think we shall try this again. Looks good.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 06-30-2015, 05:09 PM   #12
CampingGator's Avatar
Just roast them over hot coals like you would a marshmallow. Keep smoothing out the dough as you cook it. Take your time with them. They take longer than marshmallows. Toast a spot, then rotate it to the other spots until they are golden brown.
_____________________________________________
2010 Ford F-150 Crew Cab
2015 Salem Hemisphere 263RL
CampingGator is offline   Reply With Quote
Old 06-30-2015, 10:45 PM   #13
Hey, Gator. I think I must have done something wrong. I had to go into town for a part for my dish and a water run. I was really excited about trying a "woofems". KMIW When the day is winding down and you get a little itch in the gullet for something or other, but you don't want to dirty a pan just for a couple tablespoons of leftovers.
So "woofems" have been on the brain.
I picked up what they had at the grocery there. It was a Grands Homestyle Southern Biscuit. That's the right kind isn't it? The ones where you peel back some of the paper and knock it on a hard surface and the thing explodes, right?
They went over the dowel alright, but as soon as they started turning brown they started to fall off in layers into the fire. Is there something else you need to do to keep keep them together? I figured a store dough wouldn't take much heat so I kept a medium low set of coals, danged if I could keep them on the stick.
rana is offline   Reply With Quote
Old 07-01-2015, 01:13 AM   #14
Yep, that's what happened to us. We tried a couple of brands with the same result. They did brown up nicely when they hit fire though.:-)
Old 07-01-2015, 02:11 AM   #15
We call them Campfire Canolis! They get better as the sticks become seasoned, yum, although we use plain Pillsbury Crescent Rolls. We'll have to try the biscuits.
2007 Rockwood Roo 232
2002 Chev Silverado 2500 HD Crew Cab
Me and DH (aka the Bearded Guy) and as many kids and grandkids as are available at any given time.
The only thing necessary for the triumph of evil is for good men to do nothing. - Edmund Burke
KateE is offline   Reply With Quote
Old 07-01-2015, 04:51 AM   #16
I recommend Don't use flakey biscuits. The cheaper the better. Also get the Small ones that are like 8 or 10 per tube, not jumbo size.
Brian, Stacy, and the girls (11 and 8)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 07-01-2015, 08:06 AM   #17
CampingGator thanks for the idea and strat56 thanks for that link,
the link shows exactly how to make them, but what about this:
we have the original two prong long-handled metal camping forks for roasting marshmallows and hotdogs, I'm thinking of trying this: ......getting just the large 1 1/4" wooden dowel, make the pieces, drill a smaller hole that would be a firm press fit onto the prongs and using the metal camping fork for the handle...... If that doesn't work I can always enlarge the small hole, buy the wooden dowels and go that route........ If that does works, it can make two at a time, but also might need to drill the small hole off center a little to separate the two wooden pieces enough to allow two biscuits to cook without swelling into each other................anyway, thanks for the idea
fella10 is offline   Reply With Quote
Old 07-01-2015, 10:39 AM   #18
Did you ever get it sorted? I'm no biscuit guru, but not ready to give up just yet.
What kind isn't a flaky biscuit? I saw the Pillsbury Grand ones that say "flaky" in the name, so I got the other ones, but yeah.. as soon as they started browning it was a lost cause.
Old 07-01-2015, 10:46 AM   #19
Georgia Frog Rally 2018
aceinspp's Avatar
We did it different as we would rap the biscuit dough with bacon then roast over the fire. Better for ya. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-01-2015, 01:18 PM   #20
looks like the biscuits falling off is a real problem and that's easy to see how they could, with nothing there to keep that from happening. ..... Skewers!......short stainless steel skewers stuck thru the dough, into a small drilled hole, drilled across the wooden piece. That would prevent falling off, would be removed before pulling the biscuit off and would only leave a small hole in both sides of the biscuit cup.......The skewers that I've found on Amazon range from 10" to 12" and could be easily cut in half, because full length is too long to mess with, mainly because I'll be trying this idea with the two prong campfire fork idea that I mentioned in post #17 above.
