Old 03-06-2018, 09:56 AM   #1
Charbroil grill2go x200
After going back and forth a few days about whether to get a Weber, I decided to save a few cents and go with the Charbroil grill2go. I have never seen a grill heat up as fast as this one. On low it hit 600 in about 6 minutes. Have only seasoned but so far it looks like a winner, well built grill. I am now going to see if it can be converted to low pressure. The valve is part of the regulator so I am not sure...
bclinton is offline   Reply With Quote
Old 03-06-2018, 10:20 AM   #2
SeaDog's Avatar
Nice it heats up fast the. The low setting on that grill may very well be like med on others. I hope you can find a conversion kit. I ruined a coleman trying to convert it good luck let the forum know what you come up with.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-06-2018, 10:23 AM   #3
I am tempted to use it with 1 lb bottles for now. Using low should make it last a little longer without having to change bottles.
