Old 09-07-2011, 03:16 PM   #51
miatared's Avatar
Originally Posted by herk7769 View Post
I found a round 13 inch pizza stone and use it.
Same here - and it works. I leave it there all the time.
The center still gets hotter, but not as hot.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 09-07-2011, 03:21 PM   #52
MtnGuy's Avatar
Originally Posted by Silverta96 View Post
So does anyone else's oven "blow out" easily. We will be cooking and check on it and the flame is out. Then it can be a hazard trying to relight it even with a long grill lighter. No problems with the stove top. Thanks for any info!
The oven should not "blow out". Time to have that puppy checked out.
Old 09-07-2011, 04:04 PM   #53
trudinator's Avatar
I did have that problem a few weeks ago, but it only went out once. I wonder if it has anything to do with wind?
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 09-07-2011, 08:37 PM   #54
Arn
Arn
How old is your trailer? That was a common problem in 2010 models. The dealer repaired mine under warranty. Don't let him BS you & say he's never heard of it, even if your warranty has expired. Good luck.
Arn
Arn is offline   Reply With Quote
Old 09-07-2011, 09:21 PM   #55
Arn
Arn
For those of you with uneven heating & cracking with pizza stones/ceramic tiles, I got this from Wikipedia & it might help.
"To prevent fracturing of the stone by thermal shock, the pizza stone should be placed on a cold oven and heated over at least 45 minutes, and it should be allowed to cool down slowly inside the oven after switching it off."
Apparently it needs to heat through before it will heat evenly. It also absorbs moisture so as stated above do not clean it with detergent.
Arn
Old 09-08-2011, 12:07 AM   #56
Terier's Avatar
I'm not much of a cook but I do use my oven on almost every trip. It seems to cook evenly so far. Main items I cook in it are BBQ chicken & rolls. After dinner I will cook cinni rolls to eat while sitting by the fire pit. These are so easy - buy them packaged in a tin pan, pop into oven & bake, squeeze the topping, eat and then discard tin.
Old 09-08-2011, 06:23 AM   #57
camper007's Avatar
We use our oven about once per season, and that's just to warm something up.
camper007 is offline   Reply With Quote
Old 09-08-2011, 06:38 AM   #58
KyDan's Avatar
We use ours in cool weather. We also make use of one of those pizza stones
from a home cooking party years ago.
We like to fall camp at least a few times. Nothing like waking up in the
late fall with crisp blue sky morning. One of those times you can see your
breath outside! Put on the coffee (electric perk if we have it or a camp
stove percolator on the stove).
Light the oven and get out some biscuits. The stove and oven quickly take
the chill off the trailer. By the time we're dressed and finished our 1st cup
of coffee the oven is heated and in go the biscuits. Even with the stone
and plenty of pre-heating we turn the biscuits at some point so they
won't burn on the bottom.
We try to eat healthy but once in a great while ya just gotta have some
eggs, sausage, sausage gravy and biscuits.
Man it sounds good right now!!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 09-08-2011, 09:55 PM   #59
Anacortesians
Most ovens use a pilot light which you have to light with one of those gas taper things. We solved the tile-breaking tile issue by getting a pizza stone. We also bought a heavy-duty ridged aluminum baking sheet.
We use the oven at least every third day. We take Safeway's lasagna and "shepherd's" pie (I didn't knw shepherds looked after cows. The pie has ground beef in it, not lamb) we also take brown & serve dinner rolls and occasionally one of DW's Lancashire hotpots.
The folk we bought from (the original owners) said that the oven option was the main reason they picked the Georgetown.
Frank and Eileen
No longer RVers or FR owners
Old 09-22-2011, 12:37 PM   #60
Hal
Born 2 Camp
To add to the fray, yes, we've used our oven a bit, but also find it has serious hot spot issues. I've tried using one of the air-bake (2 layers of metal with air gap between) cookie sheets below the item we're cooking in, as a heat diffuser. It's the same idea as a ceramic tile, but a lot less thickness and weight involved. It has helped, but the oven still has a hot spot in the middle, so we still need to check things regularly while baking.
One thought I just had was - has anyone tried baking by placing the item below the burner? Since the oven is (mostly) enclosed, the entire space inside should heat up, although obviously less quickly below than above the burner, but has anyone actually tried this to see if it works at all?
I'm thinking of swapping the microwave for a combo microwave/convection oven and just using it instead. I've seen some mixed opinions on those ovens, though.
Anyone have any good experiences with a micro/convention combo and a recommended make/model they are happy to share?
Hal is offline   Reply With Quote
