Old 07-05-2018, 11:33 PM   #1
dutch ovens
OK ,stupid question time. Do you preheat one before you use it ? Or just add the ingredients with it cold and then put the charcoal on the top and under??
Charger is offline   Reply With Quote
Old 07-05-2018, 11:38 PM   #2
It is just like your oven at home... preheat before use. Using a temp chart, you can predict the temperature by the number of briquettes. I have a 14", a 12" and an 8" oven.
2018 Rockwood 2109S
Sahall is online now   Reply With Quote
Old 07-06-2018, 10:53 AM   #3
Head Rambler
Depends on what I'm cooking. If baking I usually preheat it but if I'm making soups, etc. I usually don't.
Gotta go campin!
Old 07-06-2018, 06:24 PM   #4
I just put the stuff in the oven. No preheat. Never a problem. 12",10", 6".
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
allenb12 is offline   Reply With Quote
Old 07-09-2018, 12:34 PM   #5
Thanks , I've been reading alot of recipes for different cobblers , apple / blue berry. I think after the weather cools a bit I'll try some of them.
Old 07-11-2018, 06:24 PM   #6
Really easy. Comes out great.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
Old 07-11-2018, 07:01 PM   #7
Cyber Phrenologist
Radio's Avatar
I never preheat. I do use a charcoal starter chimney.
I do use those parchment paper liners. Makes cleaning up a snap. And oils from whatever you are cooking seep through the paper and keep the oven seasoned really well.
If buying a dutch oven, make sure the pot has legs and the lid has a rim. There are dutch oven pots made for home oven use that do not have these features. Great for home, all but useless camping. IMHO.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 07-11-2018, 07:24 PM   #8
World Wide Wanderer
wahoonc's Avatar
Pre-heat for somethings, not for others. I typically do pre-heat for baking, not for soups or stews. To me the DO is mandatory for camp cooking!
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is online now   Reply With Quote
Old 07-12-2018, 09:42 AM   #9
Great advise everyone, I'm thinking maybe a 10 in. with the legs. I also read where some put a metal plate of sorts under it all to help reflect the heat up ? Any of yall do that? Is it necessary ? I do have a metal plate laying around somewhere.
Old 07-12-2018, 09:56 AM   #10
World Wide Wanderer
wahoonc's Avatar
Not normally, I may put down a sheet of aluminum foil to make the ash clean up easier.
Aaron
Aaron & Rhonda
