Old 06-25-2018, 01:39 PM   #1
Crazy Dog Lady
Granny K's Avatar
Low Pressure Stove for Quick Connect Port
I have searched everywhere for this and hope someone can direct me. I want a stove I can connect to my outside low pressure outlet, not a grill, not a high pressure stove that I will have to modify or use with a propane bottle. Just something equivalent to my ancient but venerable 2 burner Coleman stove, but expressly built for using the low pressure propane outlet.
I know this question has been asked before, but the answers I have seen all missed the mark.
Does such a thing exist?
"Little Toot" (2017 Forester 2391 TS)
Granny K is offline   Reply With Quote
Old 06-25-2018, 01:51 PM   #2
Kaadk's Avatar
I don't know of one that's exactly like the little portable Coleman stoves. I had gotten a Camp Chef 2 burner stove and the quick connect hose fitting. It is a modification, but not a big one. Literally just unscrew the old hose, screw in the new one. However, the Camp Chef stove is big.
https://www.campchef.com/rv-connection-hose.html
Old 06-25-2018, 02:06 PM   #3
bikendan's Avatar
Camp Chef or Blackstone.
Equalizer WDH
Old 06-25-2018, 02:21 PM   #4
craigster_mi's Avatar
I bought a 3 burner from a guy parting out a pop-up. Had the quick disconnect and mounting rail already (but it's kind of high for a short guy like me) so can hang it outside and hook right up.
craig
2014 F150 Eco
2015 Rockwood Mini-Lite 2504S
craigster_mi is offline   Reply With Quote
Old 06-25-2018, 03:46 PM   #5
Crazy Dog Lady
Granny K's Avatar
Sounds like a winner! One question. I looked on Amazon and found smaller two burner stoves.
eg. https://amzn.to/2tJEWD1
Can these also be used with the RV connection hose?
Thanks!
Old 06-25-2018, 03:55 PM   #6
Kaadk's Avatar
Thanks!
Unfortunately, probable not. The stove you linked says it's a Mountain Series, and the hose I linked from Camp Chef says it's not compatible with the Mountain Series.
But, probably doesn't hurt to try contacting Camp Chef directly to see if they have something that will work. They might have an alternative hose to the one I used.
Old 06-26-2018, 01:17 PM   #7
Crazy Dog Lady
Granny K's Avatar
I put my question to the folks at propanegear and received the following answer. The Ranger II would not be my first choice but it IS at least a solution.
The Camp Chef Ranger II is a great little two burner stove. We are currently out of stock, but we like them. Connect it to your RV's low-pressure female quick-connect with one of these hoses below (remove the hose and regulator that comes with the stove first). RV Connection Hose 12' RV Hose 3/8" Female Flare Swivel x Male Quick Connect - propanegear
Old 06-26-2018, 01:33 PM   #8
jeff64's Avatar
Both my friend and I, when we bought our TTs ( at different dealers even) asked if they would swap out the RVQ for a stove that would hang on the rail. His came with a 2 burner , mine with a 3 burner. Both Suburban and in a blow molded base. Couldn't be happier. His is a little easier to store than mine. I don't think we have ever used the inside stove
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 06-26-2018, 04:20 PM   #9
Crazy Dog Lady
Granny K's Avatar
Response from Camp Chef
Here is the response from Camp Chef. If I want a table-top stove from them, the Ranger II is the only solution.
Hello Karen, Thank you for the email. Our Mountain series stoves are all high pressure stoves, so they are not able to hook up to the RV hook up. We have two table top stoves that can be hooked up to the RV, here is the link for the 2 burner https://www.campchef.com/ranger-ii-t...ner-stove.html and here is a link to a 3 burner https://www.campchef.com/ranger-ii-t...ner-stove.html.. We do have other stoves that will hook up to the RV however they are bigger and don't sit on the table. Best Regards, Camp Chef Customer Support
Old 06-26-2018, 05:57 PM   #10
Crazy Dog Lady
Granny K's Avatar
Thanks bikendan. I checked both suppliers but only Camp Chef makes a tabletop stove. Using a hose terminated with 3/8" flare fitting X male quick connect fitting (various lengths available on Amazon) I will be able to connect a "Ranger II" 2 burner tabletop stove to my RV. This seems to be the only "off-the-shelf" solution.
pressure
