Old 05-06-2019, 08:10 PM   #1
Erinh's Avatar
LP quick connect
Help!! Iím having problems hooking my Coleman Roadtrip to the lp quick connect. Iíve purchased the hose to hook from quick connect to grill but I donít seem to be getting any gas to the grill.
Erinh is offline   Reply With Quote
Old 05-06-2019, 08:21 PM   #2
Did you remove the regulator on the Coleman Roadtrip?
Did you turn the quick connect connection lever in the correct direction to allow gas flow?
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 05-06-2019, 08:37 PM   #3
Erinh's Avatar
Did not remove the regulator from grill. I thought that might be the problem all along but someone told me no! (My husband )
Old 05-06-2019, 08:44 PM   #4
Just as confused as you
Scrapper's Avatar
DH can be wrong, just ask my DW.
Richard & Jill
Camping since 1989, seasonal since 2000
Old 05-07-2019, 07:42 AM   #5
Trailer Park Supervisor
NJKris's Avatar
Lol Scrapper. Yeah, two regulators will not play well, and the trailer quick disconnect line is already coming off the regulator at the tanks. It is the reason I gave up on using the quick disconnect, I did not want to modify my appliances for trailer use only.
NJKris is offline   Reply With Quote
Old 05-07-2019, 07:49 AM   #6
Originally Posted by Erinh View Post
Help!! I’m having problems hooking my Coleman Roadtrip to the lp quick connect. I’ve purchased the hose to hook from quick connect to grill but I don’t seem to be getting any gas to the grill.
Not only will you need the hose but you are going to have to get the adapter to eliminate the regulator on the grill since the quick connect is already regulated by the R/Vs regulator to make the system low pressure.
Here is one link to the adapter.
Roadtrip LXE Adapter
There are MANY threads on this subject here on this forum and a Google search will bring up several videos on how to do it as well.
**HERE** is one such Google search.
Days Camped: '16=46 '17=30 '18=51 '19=21
Old 05-07-2019, 07:49 AM   #7
dbledan's Avatar
I did this. You can also buy a hose for direct to quick connect.
Switched to Quick Connects for Coleman Roadtrip Grill
dbledan is offline   Reply With Quote
Old 05-07-2019, 08:23 AM   #8
you can also unscrew the existing adapter from the existing regulator. buy a quick disconnect and split it into the two pieces. put the male piece on the adapter and the female on the regulator. now you can screw the adapter into the grill and connect to either the female end of an lp extension hose from the rv or from the original regulator using the green bottles.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is online now   Reply With Quote
