Old 04-14-2015, 07:21 AM   #1
vinmaker's Avatar
Metal heat diffuser for oven
Hello all,
I was looking through the treads on using a pizza stone to diffuse the heat in the small RV ovens we use. There were so many comments on how easy they have cracked. Many said they did not care it was cracked as it still worked fine. But I am not a fan of having a bunch of pieces.
The general advice was to heat it up slowly or even leave the door open a bit so the stone can slowly heat up. But many of us find ourselves pressed for time and this seems like something that is easily skipped in our haste.
I was wondering if anyone has simply used a sheet of 1/4" plate steel to place in the oven. My wife likes her Caphalon pans because they are thick and disperse the heat much better than cheap thin pans.
The metal would not crack and would need no special slow warm up process. The plate could remain in the stove during travel as well. Just "set it and forget it".
Thoughts?
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 04-14-2015, 07:27 AM   #2
Hi,
As others have done, rather than go with one large piece, I bought four separate unglazed 6" square tiles at Home Depot, and set them in loosely. Years later, none of them have cracked.
FWIW.
Rich Phillips
richp is offline   Reply With Quote
Old 04-14-2015, 08:08 AM   #3
we have the pizza stone, 3k miles and no cracking. Some roads were a bit rough also.
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
http://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 04-14-2015, 12:09 PM   #4
cstover's Avatar
My stone cracked first time using it. Right down the middle. Guess what......still using it. No issues.
cstover is offline   Reply With Quote
Old 04-15-2015, 11:27 AM   #5
I have never had a pizza stone crack?
whj77372 is offline   Reply With Quote
Old 04-15-2015, 12:32 PM   #6
pennypoppins's Avatar
We use an "air bake" cookie sheet in our oven and it works well to even out the heat.
pennypoppins is offline   Reply With Quote
Old 04-15-2015, 03:38 PM   #7
I too use a air bake cookie sheet no problems with item burning.
edcronin01 is offline   Reply With Quote
Old 04-15-2015, 03:53 PM   #8
Boss Ox & Drovergirl
oxcamper's Avatar
Our oven is used to store skillets. Too small to do anything else in.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 04-15-2015, 03:58 PM   #9
1/4" steel plate might be a little heavy for the rack.
Old 04-15-2015, 06:36 PM   #10
davel1971's Avatar
my thoughts too. That would be very heavy. About 10 lbs per square foot so would probably be around 25 lbs.
David & Lynn
fuse
