Old 09-29-2015, 11:10 AM   #1
Outdoor Stove
Hello - We have a Rockwood Mini Lite with the outside propane grill and a
retractable gas hose. Does anyone know of a two burner stove that could be used on the attachment rail and hose. At certain times of the year it would be nice to be able to use a cook stove outside. Matt
steveanson is offline   Reply With Quote
Old 09-29-2015, 12:29 PM   #2
Old Member
mikey's Avatar
Send a message via Skype™ to mikey
In my experience, anything will work as you envision it. It might take some searching for the right parts but it should work.
Travel safe!
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
mikey is offline   Reply With Quote
Old 09-29-2015, 12:35 PM   #3
rsdata's Avatar
two burner stove
I have yet to find a two burner stove (not a grill) that works with the LOW pressure regulator/connector on the side of the TT...
does anyone know of one?
“Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 09-29-2015, 12:41 PM   #4
TURBS's Avatar
Would this not work?
Just needs the regulator removed and the quick connection installed.
http://m.target.com/p/camp-chef-expl...qCqhoCszzw_wcB
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 09-29-2015, 12:57 PM   #5
rsdata's Avatar
Turbs
I know the propane that comes out of the side hose on my TT is low pressure ( looked up the model number of the fitting and is described as low pressure) as is all of the pressure delivered through the standard propane tank regulators...
those burners look like high pressure burners to me (in the link you provided) and although that will probably light, it wont give the heat it was designed to deliver...
2014 Shamrock 183
Old 09-29-2015, 01:25 PM   #6
craigster_mi's Avatar
I currently use a 3 burner that came out of a pop-up. it already had the mounting channel to hang it where the grill goes and had the correct quick disconnect propane fitting. unfortunately I'm short and the stove was pretty high when hanging on the outside so I bought a 10' extension hose and set the stove on table that I can set out from under the awning if I want to. (extension hose works with BBQ also)
2014 F150 Eco
2015 Rockwood Mini-Lite 2504S
craigster_mi is offline   Reply With Quote
Old 09-29-2015, 01:28 PM   #7
TURBS's Avatar
Turbs
This one says low pressure.
http://www.amazon.com/Cajun-Cookware.../dp/B003GUCHRA
TURBS
2011 32bhok Sabre
Old 09-29-2015, 01:29 PM   #8
ontario_camper's Avatar
Camp Chef sells several low pressure stoves. We bought the Weekender for $120. The burners are 20 000 btu, and extremely powerful. It comes with legs, but they are quite short, so we prefer to use the stove on a table. They also sell a RV extension hose.
http://www.campchef.com/stoves/two-b...ner-stove.html
http://www.campchef.com/rv-connection-hose.html
ontario_camper is offline   Reply With Quote
Old 09-29-2015, 01:33 PM   #9
TURBS's Avatar
http://outdoorstirfry.com/?page_id=295
Here's more.
TURBS
2011 32bhok Sabre
Old 09-29-2015, 02:00 PM   #10
bikendan's Avatar
Weekender 2 Burner Tabletop Stove | Camp Chef
RV connection hose | Camp Chef
^^^^THIS
Equalizer WDH
door
