Old 05-09-2013, 12:38 PM   #11
We saw to things:
1. Took a few minutes longer to heat up.
2. Temps were slightly more even across the oven.
(Ours fits with only a small amount of space around the edges)
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 05-09-2013, 02:07 PM   #12
statgeek's Avatar
When I measured the inside of my oven, I measured 14.5 by 15.5. I saw that stone and grumbled because I didn't think it would fit. Is it convenient for you to measure that stone and verify that it really is 16" wide?? Maybe that's just what they said on the box?!
2013 Fleetwood Discovery 40G
BlueOx Aventa & Patriot Braking System
2009 Jeep Wrangler Unlimited
statgeek is offline   Reply With Quote
Old 05-09-2013, 02:10 PM   #13
Will measure tonight
Walter & Donna
Old 05-09-2013, 02:34 PM   #14
hotshott's Avatar
I've always wanted to try an oven stone but my camper is on a seasonal year round property and does not get towed. I use the top burners only. Salem Grand Villa 40FLFB. I have 3 gas weber grills, 2 weber teardrops, 1 electric meat smoker, 1 charcoal meat smoker, 1 weber Smokey Joe and my favorite is the 22 inch dual truck rims with custom made cove for beer can chicken. If I can't cook it, I won't eat it.
TT. 2011 Salem Grand Villa.
TV. 2009 F350. Dually, Lariat, Twin Turbo (after market)
w/ stock exhaust and Maramount Easy-flow muffler.
hotshott is offline   Reply With Quote
Old 05-10-2013, 12:01 PM   #15
I believe I must have had the wrong link...
American Metalcraft STONE14 Rectangular Ceramic Pizza Baking Stone 14" x 15"
As our stone measures 13 7/8" x 14 7/8"
Walter & Donna
Old 05-10-2013, 12:36 PM   #16
daydreaming about camping
jeeplj8's Avatar
Originally Posted by 38FLCamper View Post
We installed a stone in the oven back during the winter and during out first trip out this year managed to try it out...
We purchased this from American Metalcraft PS1416 Rectangular Pizza Baking Stone 14" x 16"
With Stone:
Ramped oven to 350 deg - 20 mins.
3 Temp Probes in different locations: All within 2 deg
Oven was set to 350 - controlled to 360 +-6 deg
Without Stone:
Ramped oven to 350 deg - 16 mins.
3 Temp Probes in different locations: All within 8 deg - center was hottest spot (as expected - stone test had the higher temps to outside edge)
Oven was set to 350 - controlled to and average of 355 +-8 deg
The important part is no burnt bottoms:
did the stone cover the holes in that divider above the heating element?
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 05-10-2013, 12:38 PM   #17
yes
Walter & Donna
Old 05-10-2013, 12:43 PM   #18
This might help. Two lower pics
ID:	30063   Click image for larger version
Walter & Donna
Old 05-10-2013, 12:45 PM   #19
jeeplj8's Avatar
One thing I read suggested you should not cover those holes. It was not clear why, so I wondered. Looks like your results were fine with the holes covered.
Old 05-10-2013, 12:54 PM   #20
I had a $.88 ceramic tile in ours. It lasted about 500 miles and several oven firings. The last trip we set up the camper and the wife opened the oven and our tile was in three pieces. I don't know if the heat weakened it or the ride broke it or the combination was too much for it. It seemed to make the oven temp more consistent though.
comfun1 is offline   Reply With Quote
