Old 05-10-2013, 01:02 PM   #21
Yes we have not had any problems with it so far.... We went with the pizza stone only because of the size. Could have used any one of the ideas suggested such as tiles, etc that will distribute the heat. Our stone does have small "feet" on it so there is a slight (1/8 or 1/16") between the stone and the bottom of the oven.
I have run it several times now with no sign of warpage or other problematic looking effects on the bottom diffuser pan. I will keep an eye on this as I could see where it might be a problem, but so far so good.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 05-10-2013, 03:48 PM   #22
statgeek's Avatar
Ahh. That'll fit nicely. Thanks!
2013 Fleetwood Discovery 40G
BlueOx Aventa & Patriot Braking System
2009 Jeep Wrangler Unlimited
statgeek is offline   Reply With Quote
Old 05-19-2013, 11:42 AM   #23
LittleMo's Avatar
Unglazed tile
I saw on one forum how you can go to Lowes and get an unglazed tile and it is much cheaper. (tera cotta, etc)
LittleMo is offline   Reply With Quote
Old 05-19-2013, 01:07 PM   #24
Yes you could do that... but we use the stone as an actual pizza stone occasionally for some home made pizzas... (Prefer over store bought/delivered)
Walter & Donna
Old 05-19-2013, 01:49 PM   #25
DAISY BOYKIN's Avatar
DW found this trick----------------
Dw found this trick on one of the cooking channels. If you are using a dark non stick pan to bake Cinnamon rolls, wrap the bottom of the non stick pan with heavy duty cooking aluminum foil. I didn't believe her when she told me to try it. Well it worked, no burnt bottoms of any kind of rolls. It really works.
I even burnt rolls with a pizza stone in the oven but after the foil trick, it works.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
DAISY BOYKIN is offline   Reply With Quote
Old 05-20-2013, 09:43 AM   #26
WestCoastRV'er's Avatar
Do you mean the non cooking side?
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 05-21-2013, 05:38 AM   #27
Non-stick any kind of pans
When using the ovens in the RV's, they are notorious for burning any kind of baking items on the bottom. As stated above, when using any kind of non-stick pan (even muffin pan) simply wrap the (insulate) outside bottom of the cooking pan with cooking aluminum foil. You will not believe it, but it works.
2019 WILDCAT 28 SGX
Old 05-23-2013, 09:03 AM   #28
I tried a tile from Lowes and was surprised how evenly things now cook.
jmswms is offline   Reply With Quote
Old 06-01-2013, 09:55 AM   #29
Put 2 layers of tin foil on the bottom last night. Amazing....
Cookies came out perfect.
thanks
3P ProPride Hitch
RV Mods
Wandering RV Life
Old 06-01-2013, 10:08 AM   #30
Phat Phrog
RVChick's Avatar
thanks
Thank you Daisy and WestCoast for the scoop on wrapping the pan bottoms in foil!! I am wanting to make cookies and didn't want to waste them by burning them!! I will try your remedy!!
Kenny n Karen
TV: 2017 Chevy Silverado 3500 LTZ - named Betty
RV: 2017 Columbus 366RL - named Karen’s Camper
RVChick is offline   Reply With Quote
Old 06-01-2013, 10:22 AM   #31
MC9
I covered the pizza stone with foil so pie drips wouldn't wreck it. The oven overheated, cooked the stone black and broke it to pieces.
MC9 is offline   Reply With Quote
Old 06-01-2013, 12:04 PM   #32
Biscuits baked today. No more burnt bottoms.
Thanks,
Daisy
3P ProPride Hitch
RV Mods
Wandering RV Life
Old 06-01-2013, 12:28 PM   #33
Camping Buddys's Avatar
Attachment 31908
Thanks,
Daisy
Looks good!
John, Lilly & the kids.
2013 Surveyor Select SV 305
2011 Toyota Tundra crew max 5.7
https://campingbuddys.shutterfly.com/
Camping Buddys is offline   Reply With Quote
Old 06-01-2013, 12:36 PM   #34
That's for sure, still waiting on pre-Goshen samples.
Old 06-01-2013, 07:46 PM   #35
Phat Phrog
RVChick's Avatar
Thanks,
Daisy
Excellent!!!
Kenny n Karen
Old 07-28-2013, 03:49 PM   #36
I wonder if cutting made it break? We have a round one that is 13 inches diameter, so it will fit in our oven and still allow air to circulate
ValMelton is offline   Reply With Quote
Old 07-28-2013, 04:25 PM   #37
slide5r4fun's Avatar
Great tip Daisy, thanks for sharing. Can't wait to try it.
Kevin & Janine
2019 F350 Lariat DRW
2020 Jayco Pinnacle 36KPTS
slide5r4fun is offline   Reply With Quote
Old 07-28-2013, 09:02 PM   #38
My hubby and I went to our local lowe's and also Home Depot and neither had unglazed tile (terra Cotta). I am going to check out local Habitat Humanity Restore they usually have tile there maybe we will find unglazed ones. I also thought perhaps if we could find some of the old white tiles that used to go in the old gas room heaters that they may works a bit too
since they are made for heat
Old 07-29-2013, 02:46 PM   #39
Phat Phrog
RVChick's Avatar
I just tried this, and it worked!!
Kenny n Karen
