Old 05-05-2013, 01:15 PM   #1
Oven Stone experiment
We installed a stone in the oven back during the winter and during out first trip out this year managed to try it out...
We purchased this from American Metalcraft PS1416 Rectangular Pizza Baking Stone 14" x 16"
With Stone:
Ramped oven to 350 deg - 20 mins.
3 Temp Probes in different locations: All within 2 deg
Oven was set to 350 - controlled to 360 +-6 deg
Without Stone:
Ramped oven to 350 deg - 16 mins.
3 Temp Probes in different locations: All within 8 deg - center was hottest spot (as expected - stone test had the higher temps to outside edge)
Oven was set to 350 - controlled to and average of 355 +-8 deg
The important part is no burnt bottoms:
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 05-05-2013, 01:40 PM   #2
Triguy's Avatar
Good data you've got there. I always wondered how much of an effect a stone had in the oven
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-05-2013, 02:13 PM   #3
clancythecamper's Avatar
I discovered that when I first started using the pizza stones; it's the only way to go!
Oh, and you're making me want fresh cinnamon rolls! I know your camper was smelling wonderful
clancythecamper is offline   Reply With Quote
Old 05-05-2013, 02:22 PM   #4
I tried. My oven will only do about 13-1/2 deep. I took the round stone I had and cut it on two ends so it would fit. It looked good. First time in the oven it cracked right down the middle over the flame.
Old 05-05-2013, 02:25 PM   #5
Oakman's Avatar
Great info. Did you keep the stone in the oven during travel or in a cabinet?
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-05-2013, 02:29 PM   #6
The stone just sits in the stove - it is close the sides and fits almost front to back - so even if it moves around it can't move much. It has been in there for about 200 miles now with no problems.
It smelled good and warmed up as it was only 38 deg out this morning.
Walter & Donna
Old 05-05-2013, 02:30 PM   #7
I used the pampered chef stone, left it in the oven, and cooked on a cookie sheet, not directly on the stone, tho I guess you could. I wouldn't worry about the crack, primarily you need a decent barrier between the heat source and your baking pan.
Old 05-09-2013, 10:31 AM   #8
Pizza stone
We have a 2104S mini lite. I have a pizza stone that is just smaller than the rack. It fits but am wondering about clearance to allow heat to distribute evenly on the top. Any thoughts.
Ole Buzzard is offline   Reply With Quote
Old 05-09-2013, 12:13 PM   #9
tomjsas's Avatar
I use a pampered chef round stone in my oven and it cracked after a couple years use. Pretty sure the bumping along in the oven during travel weaked it some and the heat did the rest. I leave it in there as it still provides that barrier that I'm looking for and what's it going to do...crack more
Tom
Pull-Rite 16K Super 5th
2014 Rockwood Signature Ultra-Lite 8289WS
2011 Chevy 2500HD - DuraMax (Just over 5000 miles now!)
Nights camped in 2014 - 21
tomjsas is offline   Reply With Quote
Old 05-09-2013, 12:20 PM   #10
Just ordered one for TOWTA, don't know if she'll ever use it, but...
Doesn't like to light the oven. Don't know why they don't put a piezo starter on it.
