Old 05-16-2013, 12:57 PM   #11
Herk7769's Avatar
Ours only goes off when we use the toaster and don't open and use the range vent.
Putting the toaster on or near the stove top and making toast allows the combustion exhaust to leave the camper. We have never had a false alarm when we use the range vent when cooking.
We did have a "smoke detector save" when some receipts the DW had hanging from a magnet attached to the hood caught fire. DW had her back turned and they went up like a bomb. The alarm alerted us in time to get it all swept into the sink and doused.
HAM CALLSIGN - KC3FFW
Old 05-16-2013, 01:49 PM   #12
Old car's Avatar
Ours has never gone off and I've checked it a couple of times just to make sure it's working. But we never cook inside either.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 05-16-2013, 03:30 PM   #13
FloridaPhil's Avatar
X2 on all the sensitive posts. We typically cook outside however when weather is not in our favor and we cook inside the alarm goes off constantly. Our camper is new and the power to the alarm is qired to the camper so we can't disengage while cooking. I will try the compressed air auggestion, that will move fresh air in. Althougj, possibly pulling the fuse if there is one might also work.
FloridaPhil is offline   Reply With Quote
Old 05-16-2013, 05:38 PM   #14
lindy's Avatar
In case you all haven't realized it yet the new dinner bell is a smoke alarm in our RV's
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 05-16-2013, 07:58 PM   #15
2012 Solera
I have been removing the battery every time we cook. Considered putting a switch in series with the battery, but I know I would forget to turn the switch back on. Decided to make a cover to slip over the detector, and color it bright red so I won't forget to take it back off after cooking. Found a Rubbermaid #7 food storage container (which I was using to store some old screws and bolts) is about perfect size for the detector in my Solera. Added duct tape around the lip (gives a nice friction mount) and wrapped with bright red tape.Click image for larger version
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 05-16-2013, 08:13 PM   #16
Camping Buddys's Avatar
Originally Posted by JLeising View Post
I have been removing the battery every time we cook. Considered putting a switch in series with the battery, but I know I would forget to turn the switch back on. Decided to make a cover to slip over the detector, and color it bright red so I won't forget to take it back off after cooking. Found a Rubbermaid #7 food storage container (which I was using to store some old screws and bolts) is about perfect size for the detector in my Solera. Added duct tape around the lip (gives a nice friction mount) and wrapped with bright red tape.Attachment 30686
Attachment 30687I
Another mod to ad to my list.lol
Thanks!
John, Lilly & the kids.
2013 Surveyor Select SV 305
2011 Toyota Tundra crew max 5.7
http://campingbuddys.shutterfly.com/
Camping Buddys is offline   Reply With Quote
Old 05-16-2013, 08:17 PM   #17
Garrette's Avatar
I
Genius, simply genius.
Garrette is offline   Reply With Quote
Old 05-16-2013, 09:25 PM   #18
2012 Solera
Note - while I like my plastic container solution for ease of install/remove, a plastic bag and rubber band (or something similar) would, of course, also work.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 06-09-2013, 05:49 PM   #19
Love My Sunseeker
DXSMac's Avatar
My smoke detector goes off every time I use the propane oven. I do have a wooden "stove cover" on that allows more counter space, I notice that I have to remove it when I use the oven because of the vents in the back of the stove coming from the oven. But it doesn't matter, it goes off every time I use the oven. I just remove the battery and no problem, but I have to do this every time.
My previous Sunseeker 3120 had the combination convection oven/microwave and this was never a problem. However, I decided I didn't like the combo (you can't brown meat in it. You can "cook" it, but not "Brown" it.) although it did a WONDERFUL job with baked potatoes.
I have a 3170, oven is vented outside, I open the window, I open the fantastic fan, smoke detector still goes off. Irritating!
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 06-09-2013, 08:50 PM   #20
Dennis and Julie's Avatar
Our smoke dector goes off everytime we use the toaster or oven and I turn on vent fan and open window by stove. So I too have resorted to taking out battery when cooking.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
Dennis and Julie is offline   Reply With Quote
