Old 04-21-2015, 09:04 AM   #21
TURBS's Avatar
I bought a pitboss. 820 I believe. Menards.
http://www.pitboss-grills.com/
There's better but it was at the price point I wanted to spend.
I'd consider a treager a "high" end.
http://www.traegergrills.com/
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-21-2015, 09:26 AM   #22
Arefbee's Avatar
[QUOTE=TURBS;841546]You could definitely do this on your grill!
With this.
http://pages.ebay.com/link/?nav=item...080576&alt=web
If you have a 2 or 3 piece grill grate remove one and stick this between your burners.
I've smoked on my grill "4" burner.
I put the meat on one side "2 burners off side" then light the other two burners for heat and the smoker box.
That way the meat is not over direct heat.
I've done ribs this way and the turn out pretty darn good.
Just a suggestion.
Btw thank you!
Thank you! I have to try that. Bet it makes the house smell good too if I open enough windows.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
Old 04-21-2015, 09:27 AM   #23
TURBS's Avatar
[QUOTE=Arefbee;841657]
With this.
Just a suggestion.
Btw thank you!
Yeah try smoking in a cg! Lol
TURBS
Old 04-21-2015, 09:29 AM   #24
TURBS's Avatar
Originally Posted by Toby View Post
ok thanks. Where'd you get your smoker and what model is it? Last question...until the next one.
Please research all the possibilities and make a decision based on what you want for a smoker . I don't believe you can go wrong.
However, DO NOT buy a master built electric smoker.
TURBS
Old 04-21-2015, 10:17 AM   #25
brookstone345sa's Avatar
I also just use tin foil. I wet the wood chips just like using my smoker. I wrap wood chips and poke holes in foil, gives a pretty good smoky taste. My smoker is too big to take camping. I just use this method with my propane grill
brookstone345sa is online now   Reply With Quote
Old 04-21-2015, 10:17 AM   #26
TURBS's Avatar
I've seen that to.
TURBS
Old 04-21-2015, 10:35 AM   #27
HOME
Barbecue (BBQ) Grills & Smokers | Traeger Wood Pellet Grills
TURBS
Why is the Treager considered to be better?
MartyQ is offline   Reply With Quote
Old 04-21-2015, 10:35 AM   #28
TURBS, If I every run across you at a campground you better have some ready for me. You know what the say... if you don't share don't post...oh wait that's what I say :-)
Jz5g52 is offline   Reply With Quote
Old 04-21-2015, 10:39 AM   #29
TURBS's Avatar
After looking @ both I can definitely tell the treager is built "better" .
Legs were beefier.
steel appeared to be heavier guage.
Again my opinion.
Probably would have been nice to have both side by side to compare.
TURBS
Old 04-21-2015, 11:04 AM   #30
B and B's Avatar
I purchased a Bradley Electric smoker. Automatic biscuit feed, temp and lots of room. My choice was made on portability. I take the smoker to our trottage or camping and limited cargo capacity due to a overloaded half-ton pickup. Also starting into smoking wanted something that was easy to use and didn't break the bank. I use Alder and Maple as Turbs does, tasted good on Pork. Have hickory for brisket, mix and match different woods sometimes. Also made in Canada, they also sell the same under some house brands.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
led
