Old 04-20-2015, 09:10 AM   #1
TURBS's Avatar
Smoking chuck roast for pulled beef sandwiches
1) 4-5 lb chuck roast
2) rib rub of choice, I used "famous daves rib rub"
3) prime rib rub of choice, I used "Excalibur prime rib rub"
4) olive oil
5) 2 cups of beef broth
6) 2 cups of red wine "dark beer can be substituted"
7) hickory smoking chips.
8) aluminum steaming pan.
The night before rub roast lightly with olive oil.
Rub all sides with rib rub then lightly sprinkle the roast with a little prime rib rub on all sides.
Cover roast and refrigerate overnight in steaming pan.
Please allow 6 hours the next day for smoking and cooking.
Start smoker 30 minutes prior and set to 250 to get the chips smoking , this is the temperature you'll use throughout.
Remove roast from steam pan and place directly on smoker rack.
Smoke for 1.5 hours adding chips as necessary.
Turn roast over, again directly on the rack and smoke an additional 1.5 hours.
@ which time the roast should be around 140 to 150 degrees @ the 3 hour mark.
Remove roast and put in steam pan again and add the beef broth and wine, cover the pan with aluminum foil and put back in the smoker for an additional 2.5-3 hours. Click image for larger version
The target temp now is 195 to 200, if you go over don't worry there's plenty of liquid to keep it moist.
Shut off smoker Remove roast, remove cover enough to allow steam to escape, recover and let roast rest for an additional hour or so.
After roast has rested start pulling beef apart !
I saved some of the juices for dipping the sandwich in but also to pour over the meat when storing for leftovers.
Good luck and enjoy!
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-20-2015, 09:41 AM   #2
LANShark42's Avatar
Wow, that looks awesome! I've never smoked beef. I REALLY need to get the smoker de-winterized and up and running. What kind of wood do you use?
19xx Wife (named Melissa)
2014 Akita (named Mizuki)
2015 F250XLT 6.2l V8, 4x4, Supercrew, 3.73 Rear
10K WD Equal-i-zer Hitch
2015 Coachmen Catalina 273BH
LANShark42 is offline   Reply With Quote
Old 04-20-2015, 09:43 AM   #3
TURBS's Avatar
I used hickory on this roast.
In my pellet smoker I use alot of Washington alder and maple.
TURBS
Old 04-21-2015, 05:36 AM   #4
Your pulled beef looks great. Now I have to try beef.
1beachbum is offline   Reply With Quote
Old 04-21-2015, 05:52 AM   #5
TURBS
Turbs DONT use (Poision Ivy Vines) for (Smoking or Campfires)! Youroo!!
Old 04-21-2015, 06:24 AM   #6
TURBS's Avatar
Noted!
TURBS
Old 04-21-2015, 06:24 AM   #7
TURBS's Avatar
Thank you!
TURBS
Old 04-21-2015, 07:20 AM   #8
Arefbee's Avatar
That looks awesome. Just finished breakfast, now want dinner.
That roast has some great marbelling. I don't have a smoker; I do most of my stuff slow cooker or roasting pan. I wonder what would happen if the outside was pan seared before smoking. I would hope it would retain the juices but I'm not sure if it would keep the smoke from getting in.
2011 PrimeTime Tracer 2600rls
Arefbee is offline   Reply With Quote
Old 04-21-2015, 07:36 AM   #9
TURBS's Avatar
You could definitely do this on your grill!
With this.
http://pages.ebay.com/link/?nav=item...080576&alt=web
If you have a 2 or 3 piece grill grate remove one and stick this between your burners.
I've smoked on my grill "4" burner.
I put the meat on one side "2 burners off side" then light the other two burners for heat and the smoker box.
That way the meat is not over direct heat.
I've done ribs this way and the turn out pretty darn good.
Just a suggestion.
Btw thank you!
TURBS
Old 04-21-2015, 08:08 AM   #10
Toby's Avatar
I plan on getting my first smoker this year. I will save this and give it a try. Thanks for posting!
Have you considered some cheesecake for desert?
2018 Ford F250
2019 Arctic Wolf F295QSL8
Toby is offline   Reply With Quote
led
