Old 10-12-2016, 10:30 AM   #21
B and B's Avatar
Originally Posted by AquaMan View Post
The GMG has a built in probe and wifi that will signal you when it hits a desired temp, whether it's the grill or the food. You can also control the grill from your smartphone.
Name:	ImageUploadedByForest River Forums1476286167.108371.jpg
Pretty cool app! Let's me know when it is down a stage.
B and B
Old 10-12-2016, 11:43 AM   #22
Learning a lot as I go...
Picked up a Traeger Junior for a good price at a Costco Road Show. Looked at the "suitcase" portable model and just did not feel like the cooking area was big enough. Loved the size though: it looked like one of the very few that might actually fit in my front storage compartment.
Figured the Junior was the sweet spot between size and portability. I need something I can lift in/out of the back of a 4x4 truck to take camping. Sportsmans Warehouse sells this model with a bundled 400W inverter so you can power it of a battery when boondocking (I already had such an inverter so it was good to know this would run it). From what I understand the draw during startup is 300W and drops to 50W once the burner is lit.
First thing, during the initial burn in, I discovered how awful the design of the pellet hopper is when I ran it out of pellets with pellets remaining in the hopper. I have now added sloped walls to the 3 sides of the hopper that did not have them. A bit of galvanized tin and aluminum duct tape fixed *that* problem.
My next mod was to install nutserts and knobs for the leg mounts. Traeger sells a model called the Tailgater which is a Junior with folding legs. With folded legs it can sit on a table. Well with my knob mounted legs... I can just remove the legs to do the same thing.
Dittos on the Pelletheads - Index forum site.
Have not found the controller to bother me yet, but I just may not know any better. So far everything I have cooked has come out well. It added a nice extra to the bacon one morning.
I have seen a mod to add an inside liner to help hold heat better. This seems like a VERY good idea and I may give it a try sometime. I may also put bigger wheels on it so it rolls better but the jury is still out whether I need this mod or not.
2015 Rockwood 2604WS (sold as 2016)
2014 Ford F-150 Ecoboost
stevejahr is offline   Reply With Quote
Old 10-12-2016, 12:19 PM   #23
I have a Green Mountain and it is excellent.
However, if you want a smoker that is good for a one hour or so grill/smoke job, rather than a low long smoke BBQ over many hours, just use an old wok. Place some lump charcoal inside and a simple round grill over it.
Alternatively, consider buying a smoke gun for about $100. It will allow you to smoke anything and easily put any flavors like hickory or apple on your product. A lot of Chefs are using smoke guns to impart smoky flavors on just about anything you want a smoky flavor. Basically you put in about a teaspoon or so of wood chips in it...not to be done inside your RV, of course.
Philos3 is offline   Reply With Quote
Old 10-12-2016, 01:25 PM   #24
TURBS's Avatar
Green mountain all the way!
Old 10-12-2016, 02:09 PM   #25
B and B's Avatar
The Green Mountain is RV Friendly. Pine Rock installed a 12 v outlet on the side of his trailer and plugs the cigarette plug into. Very handy guy he is!
B and B
Old 10-12-2016, 04:54 PM   #26
PineRock's Avatar
Yep, we really enjoy cooking on the davey crocket👍Click image for larger version
Name:	ImageUploadedByForest River Forums1476309196.945420.jpg
ID:	122818Click image for larger version
Name:	ImageUploadedByForest River Forums1476309256.781792.jpg
Terry & Mary Beth
Tennyson, IN
2018 palomino
columbus 298RL
2019 Ford F-350 6.7
PineRock is offline   Reply With Quote
Old 12-10-2016, 07:01 PM   #27
TURBS's Avatar
Going to do some beef spare ribs tomorrow on the Davey Crockett!
Old 12-10-2016, 07:31 PM   #28
Wobbles's Avatar
Just finished my first set of St Louis style ribs on the Davy Crockett. Very satisfied with them. Love'm actually.
I picked the right time of weather to lean the gmg. I thought I would have to increase my temps to account for the wind at 30 degrees today. That bad little boy kept up.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 12-10-2016, 08:50 PM   #29
TURBS's Avatar
Sounds great!
Old 12-10-2016, 11:31 PM   #30
ID:	126483. I did some baby back ribs on my Traeger today with pecan wood. Turned out great!
getsum is offline   Reply With Quote
Old 12-11-2016, 12:12 AM   #31
I go RV'ing not Camping
jgourlie's Avatar
Does anyone think that the green mountain would be able to attach to the bumper mounted arm grill attachment for my outsid kitchen?
We all know the barbecue that comes attached is useless.
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 12-11-2016, 09:08 AM   #32
AquaMan's Avatar
I don't see why not. May have to make your own mount, but you could bold through the feet mounts on the grill.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 12-11-2016, 09:58 AM   #33
TURBS's Avatar
28 degrees this morning,
Green mountain running with short ribs.
Old 12-11-2016, 03:36 PM   #34
TURBS's Avatar
Perfection!
Old 12-11-2016, 03:41 PM   #35
BandJCarm's Avatar
Good posts.
My Rec Tec had some paint peeling off. I called, they said it was probably due to a batch of steel that didn't get the oil used in cutting process wiped down correctly.
They then sent me a whole new one! Mine worked fine, just had a bit of paint peeling. But bam, they replaced it, no charge, no shipping, no hassle.
I love it!
FWIW...........while in Vicksburg, I was out of pellets so I got some at TSC.....which are hardwood, but made for the heating stoves. They work........but no flavor. They are only $5.00 for 40 lbs, however!!!!
Just an FYI. Make sure you get ones that are 100% hardwood, but I'm going to mix this with mequite/hickory/etc pellets for flavor........OR just chunk 'em.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 12-11-2016, 09:02 PM   #36
TURBS's Avatar
Originally Posted by BandJCarm View Post
Good posts.
I love it!
Ummm you don't want to use stove pellets, they bind them together with things you don't want in or on your food.
Old 03-12-2017, 06:33 PM   #37
TURBS's Avatar
Haven't used my pit boss in awhile, installed a pid controller and made some amazing meat for supper tonight!
