Old 12-11-2016, 12:12 AM   #31
I go RV'ing not Camping
jgourlie's Avatar
Does anyone think that the green mountain would be able to attach to the bumper mounted arm grill attachment for my outsid kitchen?
We all know the barbecue that comes attached is useless.
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 12-11-2016, 09:08 AM   #32
AquaMan's Avatar
I don't see why not. May have to make your own mount, but you could bold through the feet mounts on the grill.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 12-11-2016, 09:58 AM   #33
TURBS's Avatar
28 degrees this morning,
Green mountain running with short ribs.
Old 12-11-2016, 03:36 PM   #34
TURBS's Avatar
Perfection!
Old 12-11-2016, 03:41 PM   #35
BandJCarm's Avatar
Good posts.
My Rec Tec had some paint peeling off. I called, they said it was probably due to a batch of steel that didn't get the oil used in cutting process wiped down correctly.
They then sent me a whole new one! Mine worked fine, just had a bit of paint peeling. But bam, they replaced it, no charge, no shipping, no hassle.
I love it!
FWIW...........while in Vicksburg, I was out of pellets so I got some at TSC.....which are hardwood, but made for the heating stoves. They work........but no flavor. They are only $5.00 for 40 lbs, however!!!!
Just an FYI. Make sure you get ones that are 100% hardwood, but I'm going to mix this with mequite/hickory/etc pellets for flavor........OR just chunk 'em.
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 12-11-2016, 09:02 PM   #36
TURBS's Avatar
Originally Posted by BandJCarm View Post
Good posts.
I love it!
Ummm you don't want to use stove pellets, they bind them together with things you don't want in or on your food.
