312QBUD - Forest River - Heritage Glen
Asking $34,000 (what is left owing on loan) but willing to entertain all offers. MUST SELL DUE TO MARITAL BREAKDOWN. Located in Ear Falls Ontario Canada 312QBUD - Heritage Glen Travel Trailers
Dry Hitch Weight
855 lbs. (388 kg)
Unloaded Vehicle Weight
6,840 lbs. (3,103 kg)
GVWR
TBA (TBA)
Cargo Carrying Capacity
2,601 lbs. (1,180 kg)
Exterior Length
35' 10" (10.9 m)
Exterior Height
10' 10" (3.3 m)
Exterior Width
TBA (TBA)
Fresh Water Capacity
37 gal. (140 L)
Gray Water Capacity
62 gal. (235 L)
Black Water Capacity
31 gal. (117 L)
Awning Size
21 ft.
Double Slide Wildwood Heritage Glen Travel Trailer, Rear Bunk Bed/Trundle Bed Slide, Ent. Center/Wardrobe w/Bunk Above, Toilet, Lav., Med. Cab., Shower/Tub, Wardrobe, Dinette/Sofa Slide, Ent. Center, Queen Bed, Double Wardrobes, Double Kitchen Sink, 3-Burner Range, Refrigerator, Pantry, Overhead Cabinets Throughout, Front Pass Thru Storage, Ext. Storage, Awning
OUTSIDE KITICHEN with fridge, sink and cabinets. BBQ.
2014 Forest River Heritage Glen 312QBUD Travel Trailer
12V Deep Cycle Battery, Flat Screen TV w/DVD Player, One Touch Electric Awning, Enclosed and Heated Underbelly, Full Extension Ball Bearing Drawer Guides, Stainless Steel Kitchen Package, Radial Tires Filled w/Nitrogen, XL Grab Handle, 2 Outside Speakers, Stabilizer Jacks, Pleated Night Shades, Aluminum Wheels, Black Tank Flush, Tinted Safety Glass Windows, Skylight in Bathroom, Outside Kitchen ~ 15K BTU Ducted A/C ~ Undermount Sink ~ High Rise Faucet w/Pull Out Sprayer ~ Dealer Prep
Features
Hitch weight: 855
Axle weight: 5,980
Dry ship weight: 6,840
GVWR: 9,500
Cargo capacity: 2,600
Tire size: 15�
Awning size: 21'
HOLDING TANK CAPACITIES:
Fresh: 42 gallons
Gray: 32 gallons
Black: 32 gallons
SECURITY AND SAFETY:
LP leak detector
Smoke detector
CO detector
Fire extinguisher
Hitch light
Amber patio light
Welded heavy duty safety chains
Electric brakes (all wheels)
Outside
Vacuum bonded lamination used on 4 walls and floors
No wood framing in floors, roof and sidewalls
Walk-on roof
Fully enclosed heated underbelly
Dometic one touch electric awning (2 year warranty)
Roof is radiused for water run off
Aerodynamic front radius
Aluminum wheels with steel belted radial tires
Black frame tinted safety windows Jalousie Windows
Smooth fiberglass radiused entry door with Venetian window
Diamond plate rock guard on front of travel trailer
Swing arm entry assist handle
Full pass through storage
Upgraded ABS fender skirts
EZ-Lube axles
Powder coated and cambered I-beam frame
Enclosed docking station (FWs)
Seamless roto-cast holding tanks
Blank tank flush system
2 Power slide-outs
6 gallon water heater with direct spark ignition
Digital heat and cooling control
Outside patio hookups for the TV set
Cherry stained hardwood
Outside kitchen
Outside Shower
Livingroom
78 interior ceiling height
Crown molding trimmed slide-out
13.5k BTU ducted roof A/C
48 oversized dinette
Jumbo pull-out storage under dinette base
Large dinette picture window
TV with antenna, booster and DVD player
Cable TV hookup with satellite ready coax cable
Extra large overhead cabinets
Decorative wall light
35K BTU Suburban forced air DSI furnace
Cable TV and satellite prep
Ducted and enclosed floor heat plenum
Night shades
30 main entrance door with Venetian window
E-granite dinette table
Luxurious 18 weight nylon carpeting
Cherry interior wood
Kitchen
Double door refrigerator (Wood Finish)
Deep basin stainless steel residential sink
Microwave oven with carousel
Kitchen faucet with pull-out sprayer/raiser
3-burner deluxe range with (1) 8,000 BTU burner
Range hood with 12-volt exhaust fan and light
Beau-Flor PVC flooring
Solid wood 20 deep drawers with full extension ball bearing glides
Solid hardwood cabinet doors and drawer fronts
Wall-mounted systems monitor panel
Oil rubbed bronze hardware on cabinets
The cabinet faces are furniture grade plywood lumber core and are screwed not stapled
Trash can storage
Luxurious e-granite countertops in kitchen and dinette
Stainless steel finish on microwave, stove and dinette
6 panel hardwood front face on refrigerator
Bedroom
Serta residential mattress in RV size (Heritage Glen Advantage)
Lift up bed in master bedroom provides under bed storage
Bunks with 300lb. weight rating
Jiffy sofa IPO lower bunk
Solid bedroom privacy doors
Mirrored wardrobe with large drawers
Cabinet drawers 20 deep with full extension drawer guide
Bathroom
Black tank flush system
Shower and Tub
12-volt power bath roof vent/exhaust fan
Wooden medicine cabinet with mirrored door
Foot flush toilet
Exterior entrance door
Beau-flor PVC flooring
