Old 02-19-2013, 12:05 PM   #1
daydreaming about camping
jeeplj8's Avatar
adhesive tank heater pads (4)
I have 4 self adhesive tank heater pads from a project for our prior trailer that I never got to.
here is the link to where purchased:
[moderator edit - Members can contact seller via PM]
Looking for $35 each shipped anywhere in the continental US. or $120 for all four (4).
These are 80 watts and DC powered. I also have three black rocker switches I will throw in if anyone buys all four (4) pads.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline
Old 02-19-2013, 04:27 PM   #2
jeeplj8's Avatar
some info from original seller:
Here is an item that when needed nothing else will do! (Add these to your tanks now before you need them!) This is great insurance as when you are on the road you never know what kind of weather you may pass through! If you have ever had to replace a holding tank it is not only costly but sometimes can be a real pain just trying to find the correct one! They are easy to install (pressure sensitive adhesive), two wire connection, the heater has no polarity (+/- or -/+), thermostatically self controlled (never have to remember to turn it on or off), 13.5 volts, 5.9 amps, 80 watts, 12 x 19 inches in size (you can use more than one per tank if you often travel or have extended stays in very cold weather)
This unit can be used on the fresh, grey and or black water tanks
TIP: this unit is thermostatically controlled (automatically turns on – off as needed) you may want to add a simple inline switch if you store your coach for the winter and do not disconnect the battery
and a picture:
jeeplj8 is offline
Old 04-12-2013, 09:21 AM   #3
jeeplj8's Avatar
bump - anyone here need these?
jeeplj8 is offline
Old 08-01-2013, 08:54 AM   #4
IdahoSRT's Avatar
Are the pads still for sale?
IdahoSRT is offline
Old 08-01-2013, 09:28 AM   #5
jeeplj8's Avatar
yes - they are still sitting in my garage.
jeeplj8 is offline
