Old 08-01-2016, 11:20 PM   #1051
Left Coast
Check it out ....not perfect, but you get the idea...Click image for larger version
ID:	116042Click image for larger version
Sent from my XT1585 using Tapatalk
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
bob caldwell is online now   Reply With Quote
Old 08-01-2016, 11:51 PM   #1052
TURBS's Avatar
Originally Posted by bob caldwell View Post
Check it out ....not perfect, but you get the idea...Attachment 116042Attachment 116043
I like it!
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "22"
TURBS is online now   Reply With Quote
Old 08-01-2016, 11:57 PM   #1053
Left Coast
if fixture could cover the length of 5 holes then the spacing for lightsIf I had a better fixture and longer table, would have been a little straighter line.....2nd pole coming out better, so I might enlarge holes some to try and straighten up . Extruded alum. with a v slot and drill bushings...
Old 08-02-2016, 05:45 AM   #1054
Wolverine 1945's Avatar
Very Nice Bob !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-02-2016, 07:08 AM   #1055
Cool Bob. Good job!
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-02-2016, 11:44 AM   #1056
Bob,
Do you think your lights would make enough illumination inside the pole to allow you to drill every next hole at 90 to the last instead of in a straight line?
That way it would make the pole illuminated from all angles.
Old 08-02-2016, 12:09 PM   #1057
Left Coast
Thought of that, but tufto do with these strip lights.....a person could turn pole 180 and have lights facing trailer, but remember, you still have the holes for pining at different lengths to contend with
Old 08-02-2016, 12:13 PM   #1058
Left Coast
ID:	116111Thought of that, but tufto do with these strip lights.....a person could turn pole 180 and have lights facing trailer, but remember, you still have the holes for pining at different lengths to contend withAttachment 116110
Old 08-02-2016, 12:57 PM   #1059
Roger that.
I guess my question is... are you trying to illuminate the area around the pole with these lights or simply make the light beam 'noticeable' so someone doesn't run into them?
It would seem to me the strip light (contained within the pole) would give off enough illumination inside the pole to make it 'noticeable' no matter what direction the strip and/or holes faced.
If you are looking to use it for area illumination... different story.
Old 08-02-2016, 01:15 PM   #1060
Left Coast
Sent me your poles so I can experiment....lol....every 90 degrees around pole would work, but if one leaves the light strip loose in side pole, when you go to pin the pole at required length, the strip might be in the way and someone would surely rupture the string...and with the sticky back being so thin, if over time it gets chaffed off, your sol...on this 2nd pole, I've increased the dia. I of holes to compensate for any misalignment in my Redneck fixture....from inner to outer pole....
awning
