Old 08-18-2016, 07:01 AM   #1261
Wolverine 1945's Avatar
I drilled ours out @ the bottom,,, in hopes of making a drain !!!
3 or 4 years ago we had a flag pole in our front yard,,, it had @ one time been a light pole that was converted to a flag pole,,, over several years it must have gotten about a foot or so of water inside of it,,, then one winter it froze up and cracked this Very Heave Steel Pole !!! I still have no idea how the water got in side,,, there is no openings anywhere ??? I can't believe it could have been condensation !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-22-2016, 08:36 AM   #1262
Probably buried in here somewhere, but I can't find.
Can anyone advise me on connecting the Claw anchors directly to the end of the pole?
Would allow for one less thing to mess with by eliminating the straps.
In case you're not familiar, here is a link to the Claw. http://tweetys.com/the-claw-tie-down...JewxoC1_7w_wcB
Couple of things I've thought of:
1. Would need a quick release connector to remove the Claw for stowing, and
2. Would need some kind of turnbuckle to take up any slack (eliminating and up/down play in the setup).
Thoughts?
Brian, Stacy, and the girls (8 and 5)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 08-22-2016, 08:58 AM   #1263
Left Coast
Use a split collar that has an ID of your pole....it would be adjustable. Thread an eye bolt into it's side and one for the claw
Sent from my XT1585 using Tapatalk
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
Old 09-06-2016, 05:26 AM   #1264
Originally Posted by TURBS View Post
I am now starting to build some awning hold down poles for DOMETIC awnings.
Poles will NOT fit carefree awnings without modification to the poles.
I also do have mounting brackets available.
I have several variations that I can build.
Emt steel poles Un painted.
Aluminum poles Un painted.
Emt poles powder coated black or white.
Aluminum poles powder coated black or white.
Brackets will be powder coated the same color as poles to match.
All holes will be pre drilled and poles will be ready to bolt on. "Less paint" if you prefer.
I will ship these anywhere in the lower 48
If your interested let me know.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Are you still building the pole kits for the Dometic 9100 Series?
karpcbk15 is offline   Reply With Quote
Old 09-06-2016, 07:27 AM   #1265
TURBS's Avatar
Yes I am.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "32"
Old 09-09-2016, 04:38 PM   #1266
Yes I am.
2015 Columbus 320RS
2008 2500HD Duramax
Hey TURBS,
Will your brackets and poles work with a Solera (Lippert) power awning?
Thanks!
2017 Cherokee Grey Wolf Limited 26BH
kantonburg is offline   Reply With Quote
Old 09-09-2016, 05:09 PM   #1267
TURBS's Avatar
Originally Posted by kantonburg View Post
Hey TURBS,
Thanks!
Yes
Old 09-09-2016, 06:16 PM   #1268
Yes
Old 09-14-2016, 05:28 AM   #1269
TURBS check your PM box.
bullet97 is offline   Reply With Quote
Old 09-14-2016, 06:25 AM   #1270
TURBS's Avatar
Pm sent back
awning
