Old 03-06-2016, 02:15 PM   #421
RooVader's Avatar
Picked up my poles from Turbs today...they look amazing! What a super nice guy as well...thanks again!
I know you told me but I forgot already....does it matter which side of the larger poles is bolted on the bracket? I know one side has holes slightly closer to end.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 03-06-2016, 02:58 PM   #422
TURBS's Avatar
Awning hold down poles.
Hole closer to the end on the big pole is the top
Nice meeting you!
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-07-2016, 07:15 PM   #423
Pill Billy's Avatar
Could I see some pics of your install when you get a chance to do it? I have one of his kits in my garage waiting to be installed on my IKSS
Pill Billy is offline   Reply With Quote
Old 03-07-2016, 07:56 PM   #424
TURBS's Avatar
Pm sent.
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-07-2016, 08:30 PM   #425
Originally Posted by TURBS View Post
Save some money?
Buy a set of poles un-painted and paint yourself!
2015 Columbus 320RS
2008 2500HD Duramax
I would think it makes more sense to paint the poles rather than painting myself?
Iwritecode is offline   Reply With Quote
Old 03-07-2016, 08:45 PM   #426
TURBS's Avatar
HA! Had to read that twice before I got it!
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-08-2016, 04:54 PM   #427
TURBS's Avatar
BEHOLD! the first ever in the world powder coated aluminum poles!
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-08-2016, 04:55 PM   #428
TURBS's Avatar
Stay tuned for an install !
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-08-2016, 05:11 PM   #429
TURBS's Avatar
Remove upper awning bolt.
Install upper bracket and just snug.
Install bigger upper pole that has the hole closest to the end with supplied stainless 1/4-20 x 2 bolt and lock nut
Install lower bracket and pin but do not lock pin, also do not install lower pole yet.
While holding bracket firmly in place remove pin and pull back on upper pole to mark two holes for rivet " a helper comes in handy here"!
Drill holes and pop rivet lower in place.
Remove pole at upper mount carefully not to disturb position and drill lower hole in upper bracket and rivet into place.
Now tighten upper mounting bracket bolt and reinstall upper pole and just run locking nut down to just about touching.
Insert lower pole into upper and align stow holes and insert pin!
Done!
Repeat on second pole!
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-08-2016, 05:21 PM   #430
Wobbles's Avatar
When you get an opportunity, with the Solera type awning, do the same instructional pictures. Remember the big baloney heads that mine came with? Would be excellent instruction wise.
Just say'n.
I will be adding mine in a few weeks, God will' and the creek don't rise. I will forward some pics.
Wobbles is offline   Reply With Quote
awning
