07-30-2016, 09:12 AM
#1041
Left Coast
Next mod for poles will be using LEDs to 'light 'em up!'
Sent from my XT1585 using Tapatalk
07-30-2016, 10:13 AM
#1042
Georgia Rally Coordinator
May just get that done this weekend Very simple. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.(sold) Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
07-30-2016, 10:56 AM
#1043
OC has rachet straps that have a reel made onto them so the straps never get tangled up when storing
I have a set of those that I use to tie my ranger to my trailer. Neat set up.
Russell
07-30-2016, 10:58 AM
#1044
Left Coast
On my get it now list....
07-30-2016, 11:04 AM
#1045
We are using a couple of small Solar lanterns that we found @ Menards,,,
they have an off switch and they put out a very soft light... I use reusable zip ties to hold then to the awning poles,,, I did not want anything that would keep the neighbors up !!!
LOL !!!
07-30-2016, 11:10 AM
#1046
Left Coast
I know how I'm gonna do it. .. . just need the time.....came to me in a dream....lol
07-30-2016, 11:45 AM
#1047
I will run mine from 9 volt (small) Battery and LED strip all the way down pole with on off switch. Will stay permanently attached. Later RJD
Days camped 2019 62
08-01-2016, 08:15 PM
#1048
Three sets of black powder coated aluminum pole kits shipping tomorrow and a fourth set Wednesday, trying to make goshen deadlines and having a hard time getting aluminum for inventory, hopefully I can get them all made!
[emoji85][emoji85][emoji85][emoji85][emoji85][emoji85]
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "22"
08-01-2016, 08:40 PM
#1049
New Pop Up Owner
Will they fit a 2013 coachman clipper 104gs?
08-01-2016, 08:55 PM
#1050
What awning do you have?
2015 Columbus 320RS
2008 2500HD Duramax
08-01-2016, 10:20 PM
#1051
Left Coast
Check it out ....not perfect, but you get the idea...
08-01-2016, 10:51 PM
#1052
I like it!
2015 Columbus 320RS
2008 2500HD Duramax
08-01-2016, 10:57 PM
#1053
Left Coast
if fixture could cover the length of 5 holes then the spacing for lightsIf I had a better fixture and longer table, would have been a little straighter line.....2nd pole coming out better, so I might enlarge holes some to try and straighten up . Extruded alum. with a v slot and drill bushings...
08-02-2016, 04:45 AM
#1054
Very Nice Bob !!!
08-02-2016, 06:08 AM
#1055
Cool Bob. Good job!
08-02-2016, 10:44 AM
#1056
Bob,
Do you think your lights would make enough illumination inside the pole to allow you to drill every next hole at 90º to the last instead of in a straight line?
That way it would make the pole illuminated from all angles.
08-02-2016, 11:09 AM
#1057
Left Coast
Thought of that, but tufto do with these strip lights.....a person could turn pole 180 and have lights facing trailer, but remember, you still have the holes for pining at different lengths to contend with
08-02-2016, 11:13 AM
#1058
Left Coast
Thought of that, but tufto do with these strip lights.....a person could turn pole 180 and have lights facing trailer, but remember, you still have the holes for pining at different lengths to contend with Attachment 116110
08-02-2016, 11:57 AM
#1059
Roger that.
I guess my question is... are you trying to illuminate the area around the pole with these lights or simply make the light beam 'noticeable' so someone doesn't run into them?
It would seem to me the strip light (contained within the pole) would give off enough illumination inside the pole to make it 'noticeable' no matter what direction the strip and/or holes faced.
If you are looking to use it for area illumination... different story.
08-02-2016, 12:15 PM
#1060
Left Coast
Sent me your poles so I can experiment....lol....every 90 degrees around pole would work, but if one leaves the light strip loose in side pole, when you go to pin the pole at required length, the strip might be in the way and someone would surely rupture the string...and with the sticky back being so thin, if over time it gets chaffed off, your sol...on this 2nd pole, I've increased the dia. I of holes to compensate for any misalignment in my Redneck fixture....from inner to outer pole....
