03-14-2017, 03:11 PM
#1441
How much are these shipped to So Cal 92587? I would want the black ones for my TT. Thanks.
2017.5 Rockwood Ultra Lite 2905WS (all the options)
New TV- 2017 Ram 3500 SRW Sport 4X4
Old TV- 2007 Dodge Ram 1500 Sport (Hemi)- towing vehicle
03-14-2017, 03:23 PM
#1442
alternative to rust and polishing
Originally Posted by Wolverine 1945
I drilled a small hole in the bottom of mine,,, hopping they would be able to drain ??? Maybe we should remove inner pole during storage ???
another option for the poles are gray pvc conduit, ... they have a "lifetime" color, easy to make, 1" into 1 1/4" is a good fit, and IMO they have a nice look, ............
03-14-2017, 04:42 PM
#1443
Fella,
Is the foot a block of wood? Also, what is the upper bracket - source - thanks
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
03-14-2017, 05:42 PM
#1444
Pm sent
03-14-2017, 05:44 PM
#1445
Originally Posted by WolfWhistle
Fella,
WW
Looks like old coots brackets.
03-14-2017, 05:48 PM
#1446
Fella,
WW
each foot is two squares of 1/2" plywood, ... the top one, I drilled thru w/hole saw, then attached the two pieces together with screws and painted, ... creates a blind hole, ... I did it that way because I didn't want the 1/4" center hole that the hole saw would leave thru the bottom piece and allow ants to enter the poles undetected, ....
the top bracket is OC's bracket(they are actually the primary piece to all the leg ideas that I know of, and very well made), ... I did have to spread the brackets open just a little to fit the 1" pvc, .... using a large c clamp, I forced a socket down between the arms(they flared out a little), then I used a second c clamp to bring them back in square, ... it doesn't take much, but was necessary to fit that size pipe(and right now, I can't remember what size socket, I think it was trial and error to get it right), ...
03-14-2017, 06:32 PM
#1447
Left Coast
Cold there Turbs?....
03-14-2017, 08:37 PM
#1448
Originally Posted by bob caldwell
Single digit lows tomorrow morning.
03-14-2017, 09:42 PM
#1449
Bob,
That is just cruel....
Turbs,
I feel for you, it will be a balmy 11 here...
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
03-14-2017, 09:54 PM
#1450
Originally Posted by SailorSam20500
Bob,
Turbs,
10 degrees at 900 pm, real feel 7
03-14-2017, 10:28 PM
#1451
Phat Phrog Stunt Crew
95 here in Casa Grande, Az. and I was trying to paint my park model.
2014 Wildcat 327ck
03-15-2017, 07:13 AM
#1452
In the 30's here in Myrtle Beach now. Going to 50 later.
03-15-2017, 07:23 AM
#1453
2 degrees this morning
#1454
Originally Posted by aceinspp
My strap has the S hook and work fine. Later RJD
I think the hooks on the new straps I bought this fall are too large to fit in the brackets,,, so I will probably need to use S hooks ???
03-15-2017, 07:32 AM
#1455
Very Nice,,, not sure what the orange bag is ???
03-15-2017, 07:38 AM
#1456
Sun Shining very brightly,,, Sky is very brillant Blue,,, @ 10 degrees !!!
03-15-2017, 07:55 AM
#1457
Left Coast
Really cold here also.......60!
03-15-2017, 07:56 AM
#1458
Elind, what kind of paint are you using in 95 degree heat? Youroo!!
03-15-2017, 08:13 AM
#1459
Maybe it is heat resistance paint ???
03-15-2017, 08:55 AM
#1460
orange bag? ... you must mean the brown pipe insulation(w/orange tape), covering the bracket that holds the post to the awning arm when traveling, ... didn't take but one time hitting my bald head on that bracket, to know that thing needed to be wrapped in something soft, ... the orange tape is to make it noticeable, the bungee cord holds it in place, ...
