Closed Thread
Old 07-05-2016, 03:42 PM   #971
2007 WildCat 32QBBS
05CrewDually's Avatar
Originally Posted by Iwritecode View Post
I was thinking the same thing. In the pic of the Fuzion, it looks like the poles would still be there had they been installed.
I'm actually a big proponent of the poles and would like to get some myself eventually, but if the awning is going to rip away from the trailer itself, there's not much you can do.
My point exactly. Not knock'en them but poles aren't going to stop it from bowing and filling with water. They all failed to give the water a route of escape. The material can only hold so much. You have to angle it.
05CrewDually is online now
Old 07-05-2016, 03:55 PM   #972
To be fair to Turbs, it's easy enough to angle the awning and still use the poles. You just have to set one lower than the other.
But the wind can still blow enough to tear the awning away from the trailer. Especially if it's been weakened by the pinholes they all seem to develop over the years. At that point the poles only keep the anwing from blowing across the CG.
Iwritecode is offline
Old 07-05-2016, 04:05 PM   #973
SeaDog's Avatar
I think the poles would also limit the amount of damage from movement to the structure prior to the fabric letting go. I used my poles in heavy rain (no heavy wind) with one side lowered and the water ran off fine.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
SeaDog is offline
Old 07-05-2016, 04:14 PM   #974
Originally Posted by TURBS View Post
USPS says they are out for delivery.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
Awesome! I wonder where they will leave them (this is always so fun with the post office) They won't fit in the mailbox, so its either my front porch or I'll get one of those orange tags to go pick them up. I hope they are on the porch, the local post office is NOT the best.....
Will keep you posted.
G
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
ChrisAndGarren is offline
Old 07-05-2016, 04:19 PM   #975
With the poles, you can also use de-flapper poles to keep the awning material from whipping and flopping which is what tears things up. The pictures only show one de-flapper on each end, I now have 2 for each end which I will use in FL this winter.
Name:	Awning deflapper 1.JPG
ID:	113175   Click image for larger version
Name:	Awning deflapper 4.JPG
ID:	113176   Click image for larger version
Name:	Awning deflapper 6.JPG
OldCoot is offline
Old 07-05-2016, 04:21 PM   #976
AquaMan's Avatar
For our 2 week road trip, I was the only one in our caravan that had their awning out all the time. The GTown triple poles worked great plus I got free installation at the factory and stayed at their "Lost Wheel Campground" for free!
2016 Georgetown 364TS
Nights Camped 2017 - 29
AquaMan is offline
Old 07-05-2016, 07:19 PM   #977
TURBS's Avatar
Originally Posted by OldCoot View Post
Would you re-post?
2015 Columbus 320RS
2008 2500HD Duramax
TURBS is offline
Old 07-05-2016, 08:46 PM   #978
How long is the inner bottom tube or is it solid rod?
OldCoot is offline
Old 07-05-2016, 09:04 PM   #979
AquaMan's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
It doesn't look like it, but the poles are extended beyond 11' and the straps are 14' long. That's why my Georgetown needs triple poles.
AquaMan is offline
Old 07-05-2016, 09:07 PM   #980
G
Apparently I was living right today.....pulled up at 615pm and the mail carrier was still putting mail out at our boxes, so I stopped and asked her about my package, she said yep, she had one big long box! Showed her my ID, which luckily matched. . Off I went home with my poles. Excellently packed, I may add. Will try to install this weekend if our spot allows us to extend the awning.
Were there some directions? I remember seeing them somewhere online.....
Garren
Closed Thread
awning
