Old 05-17-2016, 06:02 PM   #801
TURBS's Avatar
Awning hold down poles.
Don't stick down below but may an inch on this set.
Normally they don't stick below at all.[emoji6]
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
TURBS is offline
Old 05-17-2016, 06:07 PM   #802
Georgia Rally Coordinator
aceinspp's Avatar
Mine better yet. Later RJD
ID:	108172   Click image for larger version
ID:	108173   Click image for larger version
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
aceinspp is offline
Old 05-17-2016, 06:25 PM   #803
TURBS's Avatar
Looks good!
TURBS is offline
Old 05-17-2016, 06:28 PM   #804
I guess that's why mine extend higher than yours. My inner poles are 68" long and outers are 60".
Name:	New lower stow bracket.jpg
ID:	108178   Click image for larger version
OldCoot is offline
Old 05-17-2016, 06:28 PM   #805
aceinspp's Avatar
Thanks. Glade I waited as you mentioned to install lower brackets. Worked out great. Later RJD
Days camped 2019 62
aceinspp is offline
Old 05-17-2016, 06:41 PM   #806
2007 WildCat 32QBBS
18CrewDually's Avatar
Yours look upside down. Do they fill with water? It looks like rain drops would run right into the lower pipe.
18CrewDually is offline
Old 05-17-2016, 06:55 PM   #807
Turbs are upside down, I designed them (long before Turbs copied them) so the small end was in the upper bracket and the alum pad on the bottom pole has a 1/4" hole in it. After 4 years, never had water in the bottom poles.
OldCoot is offline
Old 05-17-2016, 07:14 PM   #808
TURBS's Avatar
Makes no difference.
Yours are upside down. [emoji6]
No matter how you do it rain gets in.
TURBS is offline
Old 05-17-2016, 07:20 PM   #809
Yours are upside down. BS!
Only difference is it drains out of mine.
OldCoot is offline
Old 05-17-2016, 08:02 PM   #810
TURBS's Avatar
Why doesn't it drain from mine?
TURBS is offline
Old 05-17-2016, 08:06 PM   #811
From what you've said and posted, you fill the ends with something.
OldCoot is offline
Old 05-17-2016, 08:09 PM   #812
TURBS's Avatar
Yeah but the stow pin hole is right at the top of the plug [emoji6]
TURBS is offline
Old 05-17-2016, 08:13 PM   #813
Still bet there is water in them, but whatever you say.
OldCoot is offline
Old 05-17-2016, 09:08 PM   #814
AquaMan's Avatar
I think Turbs just filled a gap in the market because you refused to ship. First rule of business, if you can't supply the market, someone else will.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
AquaMan is offline
Old 05-17-2016, 09:09 PM   #815
TURBS's Avatar
You are my best customer ! [emoji106]
TURBS is offline
Old 05-18-2016, 01:37 AM   #816
SYE
SYE's Avatar
My bottom pole always has water in it as they have no drain holes.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline
Old 05-18-2016, 04:10 AM   #817
Witch Doctor's Avatar
Dually it does but mine do not have a drain whole in the bottom, except where the holding pins go's through. but they fit pretty tight so I never had a real problem yet...
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is offline
Old 05-18-2016, 04:17 AM   #818
If you look at where that shock is located on that arming arm you could see that they shortened that wall bracket to me. I'm sure Turbs can make it work, a columbus awning is also higher then a Rockwood, so it will take more pole...I know I had to cut my rear poles down on the second awning, or I had like a 1 1/2' hanging down....Hope I'm wrong but I would measure first and order some custom ones, I have faith in Turbs.... PS: Capt. Mike has the same awning arms on his, I'm not sure how he handled it, so what about it Capt. Mike?
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-18-2016, 05:56 AM   #819
For your information, Tim, I am not , never have been and don't want to be in business. I AM RETIRED and have been since Aug 2006.!
After shipping in excess of 125 sets and having the number of problems I had with the last 25 sets and UPS, I just decided it wasn't worth the hassle. I have no problem with Turbs or anyone else copying the design/concept, in fact I'm glad he/they do, I even published the drawings for everyone. The WHOLE point of the design was strictly for the members of this forum to be able to use their power awnings.
OldCoot is offline
Old 05-22-2016, 09:02 AM   #820
Smile Awning poles
Hi Turbs:
Looking for quote on all white aluminum.Domestic awning.We have a deck off our trailer and was wondering if there is a foot of some sort avail for the bottom of the poles to mount to the deck. shipping to 54311 Green Bay,Wis.
Thank You!!
ibrnds is offline
awning
