06-16-2017, 09:22 AM
#2021
Originally Posted by OldCoot
Big difference, with the brackets, you are not putting any more load on the motor shaft like you do if you strap around the awning tube.
The strongest point of "NO Load" on the awning Tube is a Cradle directly under the TUBE at the End of the Tube! The Brackets are mounted "Outboard" of the Tube on the Linkage between the RV and the Axle attachment point of the Roller Tube! I had "Awning Supports" long before the "Self Storing" brackets that OC used to make,I bought OC Brackets for the "Self Storing" feature they added No additional Strength or Support than my original supports,just "Self Storing"! There are still MANY owners of "Electric Awning" that just Tie a Rope/Strap around the Tube End and "Think" they are "Good to Go" and NO UP support at all and ALL the Pressure on the "FLIMSY Alum Rail Tilt Arms "see it all the Time! Youroo!!
06-16-2017, 09:54 AM
#2022
I don't have a dog in this "discussion" either(other than I was an OC customer) and I think the brackets are a simple/useful design. Can you do it without OC's brackets? Yes. Fasten your poles to the awning arms using eye-bolts or anything you can attach with. Either mounted or removable and you have it. OC's brackets make it simple and clean.
IMO(in my opinion)
2017 Puma 297RLSS
06-16-2017, 10:27 AM
#2023
I'm like Iwannacamp... you guys can argue all you want about about stress on the motor/awning tube.
Here is the REAL reason you should use the OC/Turbs brackets...
Should you need to retract the awning in a hurry... with your strap and pole attached to the bracket... all you need to do is release and unhook the strap at the lower tie down and retract the awning. (I can do both in about 10 seconds as I don't use ratchet straps, I use H/D cam buckle straps)
You don't need to unhook the top of the strap, (remember, it's attached to the bracket) the strap won't try to wind up with the roller, (because you had it wrapped around there) the pole will simply lift up with the awning as it closes and lay against the awning arms and it won't fall loosely to scratch the side of the camper or bop you in the head and no worries about a screw going into the roller channel or support u-clamp that needs to come out/off before the awning can retract.
Have fun!
06-16-2017, 03:17 PM
#2024
I might have poles and brackets some day.....
2015 Ram 3500 CC SRW SB 6.7 Cummins
2015 Sabre 36QBOK-7
Nights Camped, 2015: 23, 2016: 27, 2017: 29, 2018: 22, 2019: 29
06-16-2017, 03:59 PM
#2025
Originally Posted by fella10
I suppose you're using the poles to support the awning tube?? .... not the awning arms like OC's design does, ... if that's the case, then, yes, the pull down force is not on the motor, .... but how you're doing that is not clear, and as I suggested early on, some pic's of this wonderful new idea would be helpful, .... BUT, if you're not supporting the awning tube with the poles, but supporting some place else like the arms, and still ratcheting down on the awning tube, then my statement about damaging the motor stands, .... and like has been stated many time before, "if there ain't pic's, it didn't happen" .....
Who said ratcheting DOWN? No need to ratchet down. No need to even put pressure on it. It just a safety strap. If the wind is going to pick my poles off the ground it is time to roll it in period. Please Tell me what do the other 1.5 mil people do with there awnings. Been camping a long time without any. As I stated I think they are a good idea that Turbs and OC developed. But really not a necessity....That is my point only, and no pics that you requested any camper will know what i'm talking about. Different strokes for different people....You have a blessed day...
PS: I hope we can agree to disagree. Plus my reply was to Russ on where to find brackets cheaper that he wants to use and make his own poles, I have no DOG in this fight...
Coachmen M/H
Concord
2018 / 300 DSC
06-16-2017, 04:11 PM
#2026
Originally Posted by RusLwt001
The PVC is a great idea. They do look good. I could probably do that myself, but I am not sure about the pieces for the awning attachments. Any hints or blueprints would be great. Nice work.
The "blueprints" for OC's Brackets are free to Forum members.
They are in the files section of the forum.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-16-2017, 04:16 PM
#2027
I agree. Very easy to pull the pins, pull down on the strap, unclip the tie-down strap from the top bracket on each side and hit the remote roll up button on your FOB. (You did install Turbs "coolest awning mod ever"? right?). Pin the legs back up to the arms at your leisure.
http://www.forestriverforums.com/for...mod-20827.html
http://www.ebay.com/itm/Hot-DC-12V-2...QAAOSwkShY-Lbv
When the storm passes, just roll out the awning and pull down each side to clip on the pre-measured straps. Lift up and re-pin the legs; done.
06-16-2017, 05:38 PM
#2029
. do you really expect a person on this forum to buy the metal have it cut by laser and try to form it without a die and press... :roflblac k: Now I Have heard it all, just buy them at West Marine... Sid Brown has bought bottom clamps there that you don't even need to pin as what was designed. I think people are starting to get carried away here...Still a good product but there are other avenues, ....
Coachmen M/H
Concord
2018 / 300 DSC
06-16-2017, 05:48 PM
#2030
Originally Posted by Witch Doctor
You must be unsure of your point. Too many Emoticons. Look, I'm not using any!
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
06-16-2017, 06:35 PM
#2031
How do I get the brackets?
thanks
Retired Auto body teacher
2021 Arctic Wolf 3550 Suite
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
06-16-2017, 06:59 PM
#2032
Georgia Rally Coordinator
Ok whats the difference you have the poles and so hook at top and no hook tie around awning not difference. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
06-16-2017, 09:45 PM
#2033
With all due respect, I hope you don't do any engineering work for anyone.
2018:16
Total 239
06-16-2017, 09:54 PM
#2034
'With all due respect'.... Now that's just funny!!!!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
06-17-2017, 08:04 AM
#2035
Canadian Member
Herk, the original reversible momentary remote switch is no longer available and the product you linked to doesn't appear to have a reversing current function. I found this current eBay ad that seems to be about the same as the original ad from 2012. It has the same remotes with arrow buttons rather than channel numbers. You just need to wire to the board yourself.
12V DC 2 Pole reversible MOMENTARY ON motor switch with 2 wireless remote RM66
06-17-2017, 09:10 AM
#2036
And it is boring, to me the forum is informational and to have fun, look no emoticons, BORING.
Coachmen M/H
Concord
2018 / 300 DSC
06-17-2017, 09:16 AM
#2037
thanks
PM Trubs on the forum, I understand OCE IS out of business again, his son MARTY, will start making them in Sept. He might still have a few, but I think he is out. Try and PM him under " old coot" hope that helps....
Coachmen M/H
Concord
2018 / 300 DSC
06-17-2017, 10:23 AM
#2038
Thank you. When I saw the original link was bad I looked for a replacement and picked the wrong type. Thank you for correcting that.
06-29-2017, 08:16 AM
#2039
I saw a post stating that drawings for the brackets are available, but I haven't been able to find them (found them for the poles, but not the brackets). Can someone please provide me a copy of the brackets drawing or point me in the right direction......Thanks...Dr JAG
-DrJAG
2015 Legacy 360RB with 2013 CRV toad. Retired USAF.
06-29-2017, 08:37 AM
#2040
X2
