Old 04-01-2015, 12:43 PM   #1061
Originally Posted by bob caldwell View Post
Senior discount....brother-in-law deal......secret hand-shake!!! Drone, pony express, snail mail??
USPS Priority Mail, no discounts!
Old 04-01-2015, 06:03 PM   #1062
Left Coast
I see.....now their collector items, soon to be seen on Roadshow.
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
bob caldwell is online now   Reply With Quote
Old 04-01-2015, 06:05 PM   #1063
TURBS's Avatar
Oc or the brackets?
TURBS
08 duramax tuned n modded, 32bhok Sabre
Old 04-01-2015, 06:07 PM   #1064
Left Coast
Originally Posted by TURBS View Post
Oc or the brackets?
TURBS
Either/or
Old 04-03-2015, 02:12 PM   #1065
DK-in-SC's Avatar
Originally Posted by Mrs Evans View Post
Did you get the poles from OC too? If not, where did you get them?
At first I just got the brackets from OC and I followed his instructions to use PVC electrical conduit to construct the poles. It isn't hard to do, and I tried hard to drill the holes straight but the finished result looked like I had my eyes closed. They were functional but ugly. When I saw he was back in the pole business I placed an order. They look so much better than the pair I made, and now when I see them I smile instead of cringe.
I live with fear every day, and sometimes she lets me go fishing.
2015 Shamrock 23IKSS
2008 Ford Expedition EL
DH-DW-D3K-DMTTSAP
DK-in-SC is offline   Reply With Quote
Old 04-06-2015, 09:40 AM   #1066
Pole end detail
Originally Posted by ChibullsAN View Post
Yep. I use these. I drilled extra holes every 2". Gets better adjustment resolution. I removed the acme style screw end part ( for the paint roller) and machined my own new end piece to attach to the brackets I made. You can always just drill a cross hole through that cast threaded piece on the end of the pole instead.
I too have the painters poles from HD and plan to order a set of brackets from OldCoot. I have a few questions if you don't mind.
Can you post a picture of the special end you machined?
Do you leave the poles attached when you travel? Is that working OK?
Are the lower brackets sized OK for those poles?
As an experiment, I picked up a decent paint rolled and cut off the handle to get a socket so I had something to screw the pole into. But then I would probably want to unscrew the poles while traveling (roller handle is only plastic) and stow them in the pass through. Keeping them attached would be better as long as they fit into the lower bracket and don't bounce around.
What type of foot do you use on your painters pole?
I am working with the idea to fit a PVC female to 3/4 inch pipe thread adapter and a pipe floor flange. Gives about a 4 inch dia. foot. I could add more surface area if needed. I also saw somewhere a plastic floor flange. Do you think the foot needs to be physically attached to the pole?
Still working out the details so all information is helpful and appreciated.
Thanks,
2015 Roo 23IKSS
2016 F150 SuperCrew 3.5 EcoBoost
Kanga99 is offline   Reply With Quote
Old 04-06-2015, 10:35 AM   #1067
Forbes's Avatar
Used the painters polls from Lowe's or HD, cut the tip off the screw into handle part and left the plug for support drilled hole thru it for attachment to top. Drilled holes in plastic handle for drainage. Used them while in FL for two months in 20 to 30 mph winds with out any problems without cross pins.
Forbes is offline   Reply With Quote
Old 04-06-2015, 10:55 AM   #1068
KDHfan's Avatar
Awning pole hold down kit
Thanks,
Here's a picture of how I went about attaching poles with a "foot"... I didn't want to deal with straps. I used OC's upper brackets, but I remove them (the poles, not the brackets) for travel.
Name:	ImageUploadedByForest River Forums1428332141.341866.jpg
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 04-06-2015, 10:58 AM   #1069
Phat Phrog Stunt Crew
elind's Avatar
I got a set of painter poles from Lowes (4'-8' @ $10.98) and hung it with the hole of the plastic handle. I then used a small paint pad screwed in the other end for my base. It is big enough to set on beach sand or a patio mat without poking holes through it.
2014 Wildcat 327ck
2015 129 nites
2016 63 nites
elind is offline   Reply With Quote
Old 04-06-2015, 11:09 AM   #1070
May I ask why you don't stow them on the awning for travel? That was the whole idea of the bracket design.
awning, modifications
