Old 04-06-2015, 01:26 PM   #1081
TURBS's Avatar
Originally Posted by Mountndream View Post
so nice to see TURBS and Old Coot getting along. Must be residual effect of a holiday
In the thread "you can't see" there's no love loss.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-06-2015, 01:31 PM   #1082
Kaadk's Avatar
Originally Posted by Kanga99 View Post
I was thinking the same thing. With a rigid pole why also use straps.
What kind of floor flanges are those and how do you attach them to the poles? Hard to see in the photos.
The simple answer is that the straps are what holds your awning down. The straps are what you need to to keep your awning from flying up. The poles act as a support to counter the downward force of the straps. Without the poles the straps would just pull the awning all the way down.
It's a symbiotic relationship. You need both for either to be effective.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 04-06-2015, 01:33 PM   #1083
Originally Posted by OldCoot View Post
As soon as the wind picks up and pulls the pad stakes and throws the whole awning back over the trailer, you'll have wished you had used the ratchet straps and dog screws.
1oo% Correct! Youroo!!
Old 04-06-2015, 01:47 PM   #1084
KDHfan's Avatar
Awning pole hold down kit
Gotta be honest... After a full season using them... There's no pulling these bad boys out of the ground. The most inconvenient part of the process is getting the flanges out of the ground on Sunday morning. In 30+ days/nights camped, they haven't budged even a little bit. Not sure why it's such an unbelievable concept when, it seems, I'm the only one who's actually tried it? And if the wind picks real real bad, I do have the straps to hook up and anchor (but I'm pretty sure I'd be bringing in the awning if it got that bad).
I got the floor flanges from Amazon... A little pricey, but worth it, IMO. There's a set screw already in the flange. I drilled out that hole with a 5/16 bit... Then continued through the pole and out the other side of the flange... Then used a lock pin for quick release.
2015 Coachmen Apex 288BHS
2014 Tundra 5.7 CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 04-06-2015, 01:54 PM   #1085
KDHfan's Avatar
Here's a picture...
Name:	ImageUploadedByForest River Forums1428342880.014178.jpg
Old 04-06-2015, 05:11 PM   #1086
Great info, thanks.
The pole and strap combo has a separate member in compression (the pole) and another member in tension (the strap) thus balancing the forces. But with the additional benefit of creating a triangle which is very strong in its own right.
Once you attach the pole to the ground it acts in both tension and compression which is great and eliminates the trip hazard. But does the top of the pole have a tendency to wander around, especially towards the trailer or towards the other pole? That movement is eliminated with straps set at an angle.
If you drive in the stakes at opposing angles it would create a wedge effect. I would bet they would never pull out. I would also devise some tool to pull them out.
With all that said. Is there a need to have any "give" in the structure? The locked down pole if done right is very rigid. Is that a threat to the integrity of the awning fabric? I have seem straps that incorporate springs or is that just for when someone trips over it?
2015 Roo 23IKSS
2016 F150 SuperCrew 3.5 EcoBoost
Kanga99 is offline   Reply With Quote
Old 04-06-2015, 05:27 PM   #1087
I've tried staking the poles down with everything but dog screws and in the FL sand, NOTHING will hold. Thus the straps and dog screws at an angle. All I can say is if you can pull the stakes, then so can the wind using the awning to increase the pulling force just like the sail on a boat. BUT, to each his own.
Old 04-06-2015, 05:42 PM   #1088
In Florida sand I would say you need two nylon stuff sacks and a shovel
As a long time tent camper I have had to resort to bags of sand or rocks to hold tent lines. Sometimes the ground just won't cooperate.
2015 Roo 23IKSS
Old 04-06-2015, 05:43 PM   #1089
Left Coast
When at the race track, we pit on pavement. So, you'll see all kinds of awning set-ups, with guys either using 5gal water jugs or coffee cans w/concrete and a eye bolt inserted for a strap. Your set-up should work just fine and with no 'trip' wire, if you don't have fido, one less thing to untangle them from. Would a nail bar help to pull out anchors? (mini crow bar) ' West coast sand for sail.'
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
Old 04-06-2015, 07:40 PM   #1090
KDHfan's Avatar
No movement or wondering with the quick pins through the holes...
Name:	ImageUploadedByForest River Forums1428363240.608968.jpg
@Bob Caldwell... Yes... I have a 13" pry bar to pull them up for the trip home.
2014 Toyota Tundra 5.7L CrewMax
awning, modifications
