Old 04-17-2015, 11:23 AM   #1141
Where do you get these awning kits from? Haven't seen them in RV stores.
Soxfan1957 is offline   Reply With Quote
Old 04-17-2015, 11:42 AM   #1142
you order it here from Oldcoot
fella10 is online now   Reply With Quote
Old 04-17-2015, 11:43 AM   #1143
Only available to members of FRF.
Old 04-17-2015, 12:02 PM   #1144
TURBS's Avatar
Originally Posted by CA Fisherman View Post
Turbs & OldCoot
I received my brackets earlier this week (thanks OldCoot) then spent several days reading and studying each and every post in this thread. Based on the (friendly?) insults and barbs back and forth between certain participants I came away not sure who are the good guys and who to believe. Anyway I am preparing to make a set of poles to go with my brackets. Being a partially disabled Vietnam veteran I need to select the best solution the first time and do it right the first time. Works best for me to get everything I need with only one trip to HD or Lowes including poles, feet, etc.. OldCoot, for the long haul will the electrical conduit work better than the PVC? Turbs, I could use a few more details on what you used for heat shrink material and how it was applied. Also looking for recommendations as to what is best for the "feet". Thank you gentlemen (I think).
Thin wall heat shrink. "Use heat gun to shrink"
See if this helps.
For my I used 1/2" solid round stock 3" long drill a 3/16" hole in bottom the pop riveted a washer on it then drilled a 3/16" hole thru the tube and round stock and riveted in .
http://m.lowes.com/pl/Heat-shrink-tu...ols-Electrical
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
TURBS is online now   Reply With Quote
Old 04-17-2015, 12:26 PM   #1145
keeprr's Avatar
How much and what is the description? Do you ship?
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
keeprr is offline   Reply With Quote
Old 04-17-2015, 12:28 PM   #1146
keeprr's Avatar
Originally Posted by OldCoot View Post
Still have 5 kits left.
How much and do you ship? Do you have details online?
Down to 4 kits left and summer is coming along with the wind.
Old 04-17-2015, 12:29 PM   #1147
TURBS's Avatar
He's Making bracket kits right now.
Should be available soon.
Poles you have to make yourself.
TURBS
Old 04-17-2015, 12:42 PM   #1148
See post 1242
Old 04-17-2015, 01:28 PM   #1149
BamaBob's Avatar
Down to 3 kits until I can get more made, which will take at least a week or more to get the nuts, bolts, hitch pins, rivets and brackets cut, formed drilled, bead blasted, etc.
OC - are you planning on making any more pole kits when you get back from FL next year?
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is online now   Reply With Quote
Old 04-17-2015, 01:52 PM   #1150
Senior Member - Retired
Thanks TURBS
See if this helps.
Lowe's Home Improvement
Attachment 74496
TURBS
TURBS
The additional information helps. Making my material list then off the Home Depot. I hope to also locate paint that is close enough to my dark browning awning arms so I can paint the brackets. Plan to drill the awning arm so I can add the second SS bolt to each bracket.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
CA Fisherman is offline   Reply With Quote
awning, modifications
