Old 05-14-2015, 12:02 PM   #1291
lgray's Avatar
Originally Posted by TURBS View Post
How do they know they arnt factory installed?
I find it hard to believe the insurance company would even have a clue.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Awning claims cost RV insurance carriers a lot of money. Many are looking for reasons to deny these expensive claims. How will you respond if and when the claims adjuster asks you if you have modified the awning or tied down it down?
You could lie, but that would be insurance fraud…
lgray is offline   Reply With Quote
Old 05-14-2015, 12:04 PM   #1292
TURBS's Avatar
The wind caused the problem not the awning tie down that's what I'd day.
TURBS
Old 05-14-2015, 12:09 PM   #1293
I have seen a Hell of a Lot of Awning (OVER the TOP) of RVs! and that is NOT a LIE! But NONE that were (Properly Secured) have I seen (OVER the TOP)! Also No Lie! Youroo!!
youroo is online now   Reply With Quote
Old 05-14-2015, 12:12 PM   #1294
Left Coast
Originally Posted by lgray View Post
Not sure about any warranty issues being raised; the gentleman I spoke with had an insurance claim issue. My assumption would be that an insurance carrier would view the structural changes made to the awning by adding this device, as interfering with the awnings ability to flex. Some of the new models even self retract.
Only if they have a wind gauge, and those that do, have the ability to turn that function off
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
bob caldwell is online now   Reply With Quote
Old 05-14-2015, 12:18 PM   #1295
lgray's Avatar
TURBS
Damage from “Wind” is a “Covered Peril” under most policies, “Comprehensive” portion/section.
A "Modification" to a fixed structure is often an "Exclusion".
Old 05-14-2015, 01:02 PM   #1296
Canadian Member
itat's Avatar
I can't see the risk of awning damage from wind being any higher with a properly secured electric awing using OC's kit than it would be if you had a factory-installed manual awning tied down the same way.
lgray's point that an insurance company may try to deny a claim based on a modification of the awning is plausible but I'd suggest that that insurer would try find another reason to deny your claim if you hadn't modified the awning. Some insurance companies are just not reliable for paying reasonable claims without a lot of hassle.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
Old 05-14-2015, 03:23 PM   #1297
Depends on how hard the wind is blowing.
Iwritecode is offline   Reply With Quote
Old 05-14-2015, 05:42 PM   #1298
retired06's Avatar
brackets installed
Thanks OC.I got the brackets today and installed them. I called you today about the top bolt so I lowered it 3", perfect! And when I installed the lower ones, I noticed that I didn't have to drill into the poles. I squeezed them using a 1/4" bolt and nut and then the pin had just enough room to hold it good and tight. I'm using Wooster 6'-12' painting poles. Trying to post pictures.
ID:	76962   Click image for larger version
Don't worry about the mule, just load the Wagon!
2015 Grey Wolf 19RR (Wagon )
2014 F150 XLT ECO Boost max tow (mule)
retired06 is online now   Reply With Quote
Old 05-14-2015, 05:48 PM   #1299
retired06's Avatar
brackets installed
I guess you'll have to stand on your head to see them! If you do, take a picture, it might living up the mood to this thread. Thanks again.
Old 05-14-2015, 06:03 PM   #1300
Left Coast
Mounted 'em upside down.... the bracket with the strap hole is the top!
awning, modifications
