Old 05-17-2015, 01:04 PM   #1311
Evereddie's Avatar
Originally Posted by sbreen View Post
What everyone using for poles for the brackets that OC is selling?
Using Wooster poles from Home Depot. I like the click lock mechanism. When I played with the twist to lock I found I could make it slip if I polled down on it. I modified the Wooster poles to make it a little shorter. These are the 6 to 12 foot ones. I am adding more holes to it right now so it can have more lock points. Will be painting mine too.
Evereddie is online now   Reply With Quote
Old 05-17-2015, 01:10 PM   #1312
DK-in-SC's Avatar
I made a set of poles using grey PVC electrical conduit. They worked fine but when OC made a limited run of metal poles earlier this year, I picked up a set and swapped out the PVC poles. He did a much better job of drilling holes than I did and they look a lot better.
I live with fear every day, and sometimes she lets me go fishing.
2015 Shamrock 23IKSS
2008 Ford Expedition EL
DH-DW-D3K-DMTTSAP
DK-in-SC is offline   Reply With Quote
Old 05-17-2015, 01:19 PM   #1313
I chose to use the gray pvc electrical conduit, ....1" into 1 1/4" ,.....I like the look of the gray post, a lifetime color with no need for paint or polish,......used them for the first time this week......really like what they add to the use of the awning,....they are just a little heavier than the aluminum or fiberglass poles would be, but nothing to be a problem, .....they have the feel of a very substantial package, not flimsy at all, and I like that......I drilled my holes 6" apart
we just got home from the campground, will add some photos later
fella10 is offline   Reply With Quote
Old 05-17-2015, 02:34 PM   #1314
BTW, I still have 10 kits left to sell and that will be the end of them until late fall or early spring next year.
Old 05-17-2015, 03:29 PM   #1315
Go back to #1411. A bit on the spendy side, but lightweight and pretty much "pre fab'd". Shoot a few more holes and a paint job... That'll get'r'done. If I remember correctly I think I paid around $30 piece and added feet to mine.
If you go back a ways in this thread OC's got diagrams of his PVC poles that will cost a fraction of what I spent. Very concise and you could knock them out in an hour or so.
rana is offline   Reply With Quote
Old 05-18-2015, 04:06 AM   #1316
wicked1's Avatar
Originally Posted by retired06 View Post
OC, I got to thinking about what you said about the poles dropping. So I went to Ace Hardware and got some 1-1/4" i.d. vinyl tube. I'm going to cut it about 2 " long then slice it so it will slip over the fiberglass but first I'll mark the poles then tape it, and spray it with locktight adhesive and put two SS worm drive clamps per pole. I didn't like the idea of drilling the fiberglass handles, their pretty thin.
I would be interested in photos so I can see what you guys are talking about, thinking of getting a set of brackets but would like to see how they are mounted and what they look like extended.
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2015 FR Rockwood Roo 23IKSS
wicked1 is online now   Reply With Quote
Old 05-18-2015, 04:17 AM   #1317
If you look back through this thread there are quite a number of photos. They're worth their weight gold. I would probably get your order in fairly quickly though. From OC's recent post I think he only has 10 sets or so left. Those are going to go pretty quick.
Old 05-18-2015, 03:39 PM   #1318
my gray pvc post #1
ID:	77342   Click image for larger version
ID:	77343   Click image for larger version
Old 05-18-2015, 03:41 PM   #1319
pvc post #2
ID:	77345   Click image for larger version
ID:	77346   Click image for larger version
ID:	77347   Click image for larger version
Old 05-19-2015, 09:17 AM   #1320
picked Poles up from Mike618 (thanks again) and checked out his Factory (Old Coot) install.
Can't wait to install our set as soon as return from my next two trips.
2015 Ram 2500 4x4 6.4l with 2015 Flagstaff 21FBRS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
awning, modifications
