Old 05-19-2015, 10:25 PM   #1321
Originally Posted by fella10 View Post
pvc post #2
Nice job!
Old 05-20-2015, 10:45 AM   #1322
I got black Schedule 40 PVC poles from Homedepot.com in the 1.25" and 1" sizes. They match the black awning hardware on our trailer and telescope together nicely.
2015 Rockwood 2618VS
2016 RAM 2500 Laramie Cummins Turbo Diesel
Old Bleu is online now   Reply With Quote
Old 05-20-2015, 12:01 PM   #1323
thanks OC,
Old Bleu......never thought of getting black, but it would have matched my black hardware also, the gray is just always at the Lowes and I'm pleased with the results of the gray,....
that collar ring at the top of the outside post is from the female end of each 10' piece and there to re-enforce that area, I cut them off and glued a section of it to the top end that you see,....since it is pvc, I wanted to re-enforce where I would be drilling and applying pressure on the pins from the hold-down strap,.....to accomplish that re-enforcement on the 1" inside pipe, I bought two 3/4" pipes, ........with my circular saw I cut a blade width groove thru one side the full length of the 3/4" pipe,......then I could squeeze it and force it into the 1" pipe the full length,.......thus, re-enforced strength at all drilled holes/pressure points,......
awning posts are something I've wanted for a long time and OC's brackets are a terrific product to make that happen,.....
fella10 is online now   Reply With Quote
Old 05-20-2015, 02:53 PM   #1324
I would like to purchase a set if you still have them available
Keith
98outlaw is offline   Reply With Quote
Old 05-20-2015, 02:54 PM   #1325
TURBS's Avatar
Keith
Pm sent
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "6 nights"
Old 05-20-2015, 07:36 PM   #1326
semi-senior member
denandra2's Avatar
Originally Posted by OldCoot View Post
Have never had even one complaint or issue of any kind other than how to install them. This is the 1st I've heard of anything amiss.
I am not a close friend of OC and have never met, but I have a set of his poles and when properly installed and used along with some common sense they have performed flawlessly. He put out a quality product. Thanks !!!!!
Dennis & RuthAnn
Tippy too!
Columbus (2014)320RS
2014 Ram 3500 DRW 6.7HO
Aisin 6speed Auto
SE Mo
denandra2 is offline   Reply With Quote
Old 05-21-2015, 05:26 PM   #1327
KDHfan's Avatar
Originally Posted by wicked1 View Post
I would be interested in photos so I can see what you guys are talking about, thinking of getting a set of brackets but would like to see how they are mounted and what they look like extended.
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
If you are possibly looking for poles that detach and store in your pass-through, check out my post... #1178
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 05-21-2015, 08:41 PM   #1328
I just bought a second swimming pool net pole. I had one already. That's what I will use for poles. Very light but sturdy. I will have to paint them the blue does not match the camper
sbreen is offline   Reply With Quote
Old 05-21-2015, 08:44 PM   #1329
TURBS's Avatar
Pics when done or didn't happen!
TURBS
Old 05-21-2015, 08:55 PM   #1330
Haven't had time to do them yet. I will post when complete. What are you using right now
awning, modifications
