Old 04-03-2014, 06:41 PM   #261
Originally Posted by Camping Buddys View Post
Hello OC, if you don't mind, can you send me the info. Thinking of upgrading to a 5ver and may need them.
Thanks!
John
PM sent.
Old 04-03-2014, 07:31 PM   #262
Gregg Willow's Avatar
Originally Posted by OldCoot View Post
The last 8 sets will include (2) 2-1/2" dia alum tread plate pads. A small "U" shaped strap could (not furnished) be used to rivet to the pad and then rivet the "U" to the inside bottom of the poles. The pads on the last 8 sets will be @ no charge.
You can also pop rivet the alum pad to the end cap that comes on the poles.
OC,
Mine will show up tomorrow. Will my order have the pads? I was thinking about this today trying to do some Google searching but have found nothing.
Oh, I suppose I am in the previous sets. How do we get these pads or do you have a suggestion for us early buyers?
Gregg
2016 Ford F-150 4x4 Supercab XLT EcoBoost
2012 Salem Cruise Lite 221RBXL, Andersen No Sway WDH, (2) Honda EU2000i's
Gregg Willow is offline   Reply With Quote
Old 04-03-2014, 07:42 PM   #263
Got my kit today. The workmanship is excellent. Thanks OC. Wish I could have gotten the pads but will improvise. If I can find some aluminum plate I will cut a couple of disks.
Robecage is offline   Reply With Quote
Old 04-03-2014, 07:45 PM   #264
Originally Posted by Gregg Willow View Post
OC,
Gregg
Lowes has big fender washers in the special hardware section. They might even have stainless steel ones.
Old 04-03-2014, 07:50 PM   #265
Sorry I didn't think of the pads before now. Only takes about a minute to cut them and I have the alum tread plate.
Old 04-03-2014, 08:54 PM   #266
Do you have an internet picture of that? I need to stop at Home Depot and look at the painter poles that have been mentioned.
Old 04-03-2014, 10:36 PM   #267
jtstromsburg's Avatar
Ehh. Our poles went thru an 60+ mph storm, while sitting on the north shore of a large lake last memorial day. Tornado warnings sent us away, but all was well upon our return. I've been amazed at what our 21' awning will hold up Through after tying it down. Ooh, the rest of the story was the awning wasn't deployed in the tornadic storm, but it has been out in 30+mph winds with no problem.
Stay safe.
Sent by me
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 04-03-2014, 10:49 PM   #268
KDHfan's Avatar
Originally Posted by presley01 View Post
Looking for something to use as feet / pads for the paint polls to keep them from sinking into the ground, anybody got any ideas
I'll take a pic and post my idea tomorrow when I get a chance.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 04-04-2014, 04:20 AM   #269
I received the kit yesterday. I cannot state enough good about OldCoot’s product. The brackets are very well made and made of superb material. OldCoot’s work is exemplary of excellent craftsmanship. I don’t think anyone could find a better product.
OldCoot, thank you so much!
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 04-04-2014, 06:26 AM   #270
2" dia ss fender washer Lowes. Shop The Hillman Group 1/2-in x 2-in Stainless Steel Standard (SAE) Fender Washer at Lowes.com
Old 04-04-2014, 09:13 AM   #271
KDHfan's Avatar
Here's the poles I made over the winter. Please note that these have not been tested... So later this summer you might see these on YouTube under "awning poles total fail". On the painters pole, I took out the male end, drilled out the hole and slipped through a locking pin for the upper bracket. I also drilled some holes between each of the existing holes for more height adjustments. For the bottom I bought two Hoellander aluminum floor/wall flanges (yes... Pricey)... Drilled it and the pole and slipped in another lock pin. I went with a size larger than needed on the flange to allow some movement on un-level ground. The "plan" is to use tent stakes in the corners under zero/light wind conditions... And if the wind picks up a little, add the tie downs. I plan on taking these off the camper for travel... Thus, no lower brackets.Click image for larger version
Name:	ImageUploadedByForest River Forums1396620592.748160.jpg
ID:	49100Click image for larger version
Name:	ImageUploadedByForest River Forums1396620609.090518.jpg
ID:	49101Click image for larger version
Name:	ImageUploadedByForest River Forums1396620625.124296.jpg
Old 04-04-2014, 03:44 PM   #272
Down to 7 sets left which have the 2-1/2" alum tread plate pole pads included at no extra charge. PM me for details.
Old 04-04-2014, 05:12 PM   #273
Witch Doctor's Avatar
Your old round bottoms work great on grass or dirt. But I found that if you put them on the cheap plastic rugs and secure them as I was taught by the MASTER you really do need to put either a plastic block or a small piece of wood under it. Other then that it will cut the rug. My set up I really only need one because I have 2 different size awnings . The main awning 1 leg gets a block under it but the small one clears the rug. That's the one I run into all the time when my wife sneaks that damn rum in my coke a cola or my coffee mug like OC's. It's not a big deal to do. Even through I had to pay $600.00 for the poles (2 Sets) and one came polished thanks to Lovey. You just can't beat them. I can testify that I had no problem on the water camping with 40 mph blowing. People where all scrambling around me pulling there's in and I just sat there drinking my coffee. Since OC is not going to Goshen, Daisy I will polish your poles for my bud, so you can't say he broke his promise to you. You can take what that man say's to the bank and gain interest on top of it. Don't rain on the OLD GOATS parade........
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-04-2014, 05:39 PM   #274
Originally Posted by gljurczyk View Post
...Even through I had to pay $600.00 for the poles (2 Sets) and one came polished thanks to TOWTA...
Yeah, and the bill was $800 and you still owe me $200 and that didn't include installing them and the 2 awning locks or the reinforcing of the rear stab jacks.
Old 04-06-2014, 12:35 PM   #275
These are very well made. I am glad I secured a set before they got gone. The OldCoot does excellent work.
2011 Chevy
Old 04-06-2014, 12:38 PM   #276
Thanks,
Old 04-06-2014, 05:48 PM   #277
Down to 4 kits left.
Old 04-07-2014, 08:32 AM   #278
Guess the rush is over with 4 left and no inquiries. Good indication that no need to have more brackets cut out.
Old 04-07-2014, 09:09 AM   #279
PhoneDude 8289's Avatar
Hello OC,
The rush may be over for now but I would be willing to bet that once they are seen at the campgrounds and rallies the orders will pick up. RV'rs of other makes that don't read these threads will want to know where some of us got these brackets. I for one will be happy to pass on your e-mail if that's ok with you.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 04-07-2014, 09:13 AM   #280
Hello OC,
Go right ahead.
awning, modifications
