Old 08-20-2015, 09:11 PM   #1611
Who Dares, Wins
doc73's Avatar
May have been addressed somewhere in the 181 pages but will your brackets / kits work with the LCI awnings that have the motors mounted on the ends of the arms?
Not my pic... Stolen from google...
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 08-20-2015, 09:14 PM   #1612
TURBS's Avatar
Yes, see the screw in the right pic up by the motor?
That's what u attach to.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-20-2015, 09:16 PM   #1613
TURBS's Avatar
Look @ post 395 I believe it's the same style.
Awning hold down poles.
TURBS
2011 32bhok Sabre
Old 08-20-2015, 09:18 PM   #1614
Who Dares, Wins
doc73's Avatar
Ok, thanks. I used our bungy tie downs for the first few times the last trips. They worked great but the weakness I found is they elbow / gas strut for run off collapses once I tie it off thus loosing the support the tie downs provide. Then I thought the poles might resolve the issue maybe?
2015 ChevyHD D-Max
2014 Greywolf 26DBH
Old 08-20-2015, 09:20 PM   #1615
TURBS's Avatar
Not might, WILL!
TURBS
2011 32bhok Sabre
Old 08-20-2015, 09:23 PM   #1616
May have to bend the ratchet strap tab a little more for clearance, but they should work. If not, send them back and I'll refund your $.
Looks close to this.
Name:	LCI awning with kit.jpg
Old 08-20-2015, 09:26 PM   #1617
Who Dares, Wins
doc73's Avatar
Thank you both, I found the post 339... Man the server is slow and had to search several pages at a time to get there.. LOL
I figured on re-directing the forces down the poles and not on the struts. I considered the PVC pipe poles but then I need to store the suckers..
2015 ChevyHD D-Max
2014 Greywolf 26DBH
Old 08-21-2015, 09:00 AM   #1618
retired06's Avatar
Hey doc73, I got the same awning. What I did was measure down 3 inches from the end of the arm and drilled the first hole. This will leave enough clearance so you won't have to bend the brackets and installing the nuts on the inside. You will need two more bolts and nuts though. Post #1411 shows my install.
Don't worry about the mule, just load the Wagon!
2015 Grey Wolf 19RR (Wagon )
2014 F150 XLT ECO Boost max tow (mule)
retired06 is offline   Reply With Quote
Old 08-21-2015, 09:33 AM   #1619
I used the PVC, no storing necessary. Post #1428 & 1429 shows what mine looks like. They attach and hang just like the metal poles. I did need to open the brackets up just a small bit to accommodate the larger size of the smaller PVC pipe. They may be a little heavier than the metal ones, but some advantages of the PVC is they have a lifetime color, no painting or polishing is necessary, and no inside rust to deal with, plus IMO they just look really sharp.
fella10 is online now   Reply With Quote
Old 08-22-2015, 07:14 PM   #1620
Who Dares, Wins
doc73's Avatar
Originally Posted by OldCoot View Post
Remember the old saying, "Easier to get forgiveness than permission". Just do it!
I hear that! What do your brackets run these days? PM is fine if that is how you handle the biz. Thanks.
2015 ChevyHD D-Max
2014 Greywolf 26DBH
awning, modifications
