Old 12-03-2015, 03:43 PM   #1681
Why couldn't you stick your 14" wooden dowel though the folding D-ring and screw them in just like the dog anchors?
D ring is too close to the ground. Dog anchor handles are about 3"-4" above the screws. Sometimes I even screw them down to the handles. Really don't see an advantage to them.
Old 12-03-2015, 04:03 PM   #1682
De-flapper telescoping poles?
A32Deuce is online now   Reply With Quote
Old 12-03-2015, 04:05 PM   #1683
Fair enough.
I do see an advantage though, several actually.
1. Often the ground here in the mountains is rocky and hard.
When trying to screw in the dog anchors, because the handle of the dog anchor isn't welded where it comes back and meets the shaft of the anchor, they often open up and bend apart. I've had to weld mine. These would not do that.
2. When leaving the campsite for the day (or more) we often retract the awning (even with poles) just for safety's sake but do not remove the anchors so we can re-anchor with little effort/time upon return. The dog anchor handles are a tripping hazards for the grand-kids when they all pile out of the TV and scramble like Indians. These would fold flat to the ground.
Yes more pricey, but what's a 4 year old's broken arm worth?
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 12-03-2015, 04:05 PM   #1684
Left Coast
OC has posted a pic somewhere on here.....it's pour'n out now or I'd post a pic They mount to the side od the awning arm, not in front.....stay on all the time, and allow one to use the de-flappers that the manual awnings use...simple to set up
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
Old 12-03-2015, 04:07 PM   #1685
Ok. When ever you get a chance. Something that is beneficial to have Bob?
Old 12-03-2015, 04:10 PM   #1686
I think the de-flappers are in this thread.
Iwritecode is offline   Reply With Quote
Old 12-03-2015, 04:21 PM   #1687
Too pricey and no way to screw them in the ground. Dog anchors better, at least you have a big handle to stick something in to help screw them in the ground.
The video on the Home Depot site shows using a piece of rebar thru the ring to screw it into the ground.
I have used the dog anchors to tie out our dog and they bend pretty easy if you can't get them deep enough in the ground. Maybe there are better quality dog anchors.
Charlie
charliem is offline   Reply With Quote
Old 12-03-2015, 04:21 PM   #1688
Left Coast
Those were the first 1 piece one... I saw 'em and thought they could be done like OC's poles....so I made a telescopic version and used some of the awning hardware that was already used for the awning pivot at the top.......then made a stud for the movable part of pole to stow onto while travel'n
Old 12-03-2015, 04:33 PM   #1689
Left Coast
32...I think so...I put 'em to the test last summer in a S. Dakota 40 or so breeze...worked great... as an added trial, I lowered one end of awning on it's slide thing and that also helps...
Old 12-03-2015, 05:26 PM   #1690
I used Bob's idea and had TURBS powder coat a set of emt tubes that I added Velcro to the inside of the outer poles and to the outside of the inner pole to keep them from rubbing against each other and scratching/scrapping the powder coat off. I replaced a stainless hook at the top of the awning support on the trailer with a stainless steel bolt and attached the outer pole to that bolt and the inner pole to another ss bolt on the end of the awning arm that I use with a wing nut to secure the end sunscreens we use, now I can attach the sunscreen and the de-flapper poles on at the same time using the same bolts. To stow, I just remove the wing nut, remove the pole from the bolt and telescope it to fit on the hitch pin attached to the bottom of the support on the trailer. Works great and you don't really notice them in the stowed position.
Name:	Awning deflapper 1.JPG
ID:	95501   Click image for larger version
Name:	Awning deflapper 2.JPG
ID:	95502   Click image for larger version
Name:	Awning deflapper 3.JPG
ID:	95503   Click image for larger version
Name:	Awning deflapper 4.JPG
ID:	95504   Click image for larger version
Name:	Awning deflapper 5.JPG
ID:	95506   Click image for larger version
ID:	95507   Click image for larger version
Name:	Awning deflapper 7.JPG
ID:	95508   Click image for larger version
Name:	Awning deflapper 8.JPG
ID:	95509   Click image for larger version
Name:	Awning deflapper 9.JPG
awning, modifications
