Old 07-22-2014, 10:22 PM   #511
Originally Posted by Black View Post
Still a lot better than no poles at all !
With the attaching kit, you would have it made.
Old 07-22-2014, 10:53 PM   #512
Herk7769's Avatar
Originally Posted by HSVBamaBob View Post
I'll Keep my OC mod TYVM taking down the arms and having to stow them every time? Ewwwww!
YOU BETCHA. The OC poles can't be beat and they were invented right here!
HAM CALLSIGN - KC3FFW
Old 07-23-2014, 02:47 AM   #513
Slympicins's Avatar
Me neither.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 07-24-2014, 05:35 PM   #514
KDHfan's Avatar
OC's brackets, along with my own poles, have been an absolute blessing for my camping experience. I no longer have to wonder all day long "should I run back to the camper and put the awning in"... No longer do I get up at night for the sole purpose of putting the awning in... Nor do I have to check the weather every couple hours to see if the wind is going to pick up. Thank you OC.
I do take mine down and stow in between trips and during travel. Not a pain at all.
2014 Rockwood 2306 w/Murphy Bed
2014 Toyota Tundra 5.7L CrewMax
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 07-24-2014, 06:52 PM   #515
thetiler's Avatar
Hey could you tell me where you got your poles from?
Jason
2013 F350 SB,CC Lariat Ruby Red,3.73Gears,5Star Tuned,,Line-X Bed,Extang Platinum Cover,Airlift LoadLifter 5000 Bags,Airlift Wireless Air controller,Reese Signature Series Fifth Wheel Rail Kit,B&W Fifth Wheel Hitch,2014 Flagstaff 8528BHWS
thetiler is offline   Reply With Quote
Old 07-24-2014, 06:57 PM   #516
NELA
Weezer's Avatar
I'll say it again....
our sets of OC's brackets and poles are the BEST mod EVER!
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 07-24-2014, 07:18 PM   #517
Jason
You can get some poles like this from homedepot or lowes. Painters poles. They have locking pins every 6" but I drilled them for every 2". I store them in the bumper and they attach to the brackets I made using the round aluminum pivot stud you see hanging there, that stays there all the time. They are the $33 poles and are very sturdy fiberglass and aluminum (not the twist lock kind either). Not bad.
ID:	58898   Click image for larger version
2014 Roo 21DK
2015 F150
ChibullsAN is offline   Reply With Quote
Old 07-25-2014, 07:32 AM   #518
KDHfan's Avatar
I used the same poles as shown. I drilled my holes at the mid-point of the ones that were already there (so there's a hole every 3")... Which is, in my opinion, sufficient. I also drilled a 5/16 hole near the top and use a quick release hitch pin through the bracket and pole. At the bottom I fitted the pole into a floor anchor, again using a quick release hitch pin... I put the poles into those and anchor to the ground with HD tent stakes (No messing with ratchet straps). I'll be setting up camp later today... I'll take some photos and post.
Old 07-25-2014, 07:36 AM   #519
I still have a few kits left.
Old 07-26-2014, 10:42 PM   #520
PVC electrical conduit pole
I experimented some today on eliminating the machine work required to use the PVC electrical conduit. I used 1" for the inside(upper) pole. Due to it's size, I had to machine alum slugs to get it down to the 1" required for the brackets. Today, I took a pc of 1" elec. PVC and put the end in a vise and used a heat gun to soften it enough to squeeze it down to 1" wide. Let it cool and it retained the dimension. If anyone wants to make a low cost set of poles themselves, go to Lowes/HD and get (2) 10' pcs of 1" electrical pvc conduit and (1) 10' pc of 1-1/4" electrical pvc conduit and use the dwgs in the library to cut and drill.
Dwgs can be downloaded here:
Forest River Forums - Downloads - Awning - New Updated DWG of the Poles
awning, modifications
