Old 08-16-2014, 06:20 AM   #531
Originally Posted by AquaMan View Post
Ok Coot, I'll take them, if you still have them. I was just waiting until you only had one set left. lol. Pm me
PM sent.
Old 08-17-2014, 11:19 AM   #532
And the last kit went to AquaMan Timmy Trost. In the mail for pickup tomorrow. If anyone wants a kit, pm me as I don't know right now if I will make anymore.
Old 08-17-2014, 11:25 AM   #533
Is this a (Taped Recording)?? Youroo!!
Old 08-17-2014, 11:29 AM   #534
AquaMan's Avatar
Now I'm waiting until he starts making the poles again!
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 08-17-2014, 11:49 AM   #535
Yes. Depends on whether Butler Built can plasma cut them out again. I hain't sawing 'em out on my band saw any more.
Old 08-17-2014, 08:47 PM   #536
Kaadk's Avatar
I experimented some today on eliminating the machine work required to use the PVC electrical conduit. I used 1" for the inside(upper) pole. Due to it's size, I had to machine alum slugs to get it down to the 1" required for the brackets. Today, I took a pc of 1" elec. PVC and put the end in a vise and used a heat gun to soften it enough to squeeze it down to 1" wide. Let it cool and it retained the dimension. If anyone wants to make a low cost set of poles themselves, go to Lowes/HD and get (2) 10' pcs of 1" electrical pvc conduit and (1) 10' pc of 1-1/4" electrical pvc conduit and use the dwgs in the library to cut and drill.
Dwgs can be downloaded here:
Forest River Forums - Downloads - Awning - New Updated DWG of the Poles
So, just to confirm, as I'm in the process of this right now. I followed these instructions and bought a single 10' of 1-1/4". By my calculations, after lobbing the flared end off, I'd be left with about 117". Dividing that by two I'll end up with two outer poles at 58-1/2" each in length instead of the 60" in length as specified in the drawings. I went ahead and cut them that way, first at 58-1/2, then again at 58-1/2 to account for the blade thickness. The second cut was right where the flare started so it looks like I got the most of a single pole I could.
Do you foresee any issue with that 1-1/2" discrepancy? I don't think it'll make much of a difference since the ones I saw at the rally weren't anywhere close to full extension, but I'd like to be sure.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 08-18-2014, 03:16 AM   #537
I would really like a set myself if more become available.
rana is offline   Reply With Quote
Old 08-18-2014, 11:42 AM   #538
Won't make any difference as the inner poles are more than long enough to make up for the 1-1/2".
Old 08-18-2014, 04:26 PM   #539
Brother Les's Avatar
brackets received.
Thank-you, OC
Brother Les
Old 08-18-2014, 04:36 PM   #540
Originally Posted by Brother Les View Post
brackets received. Thank-you, OC
Hope they work for you. Thank you!
awning, modifications
