04-17-2015, 11:23 AM
#1141
Where do you get these awning kits from? Haven't seen them in RV stores.
04-17-2015, 11:42 AM
#1142
you order it here from Oldcoot
04-17-2015, 11:43 AM
#1143
Only available to members of FRF.
04-17-2015, 12:02 PM
#1144
Originally Posted by CA Fisherman
Turbs & OldCoot
I received my brackets earlier this week (thanks OldCoot) then spent several days reading and studying each and every post in this thread. Based on the (friendly?) insults and barbs back and forth between certain participants I came away not sure who are the good guys and who to believe. Anyway I am preparing to make a set of poles to go with my brackets. Being a partially disabled Vietnam veteran I need to select the best solution the first time and do it right the first time. Works best for me to get everything I need with only one trip to HD or Lowes including poles, feet, etc.. OldCoot, for the long haul will the electrical conduit work better than the PVC? Turbs, I could use a few more details on what you used for heat shrink material and how it was applied. Also looking for recommendations as to what is best for the "feet". Thank you gentlemen (I think).
Thin wall heat shrink. "Use heat gun to shrink"
See if this helps.
For my I used 1/2" solid round stock 3" long drill a 3/16" hole in bottom the pop riveted a washer on it then drilled a 3/16" hole thru the tube and round stock and riveted in .
http://m.lowes.com/pl/Heat-shrink-tu...ols-Electrical
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
04-17-2015, 12:26 PM
#1145
How much and what is the description? Do you ship?
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
04-17-2015, 12:28 PM
#1146
Originally Posted by OldCoot
Still have 5 kits left.
How much and do you ship? Do you have details online?
Down to 4 kits left and summer is coming along with the wind.
04-17-2015, 12:29 PM
#1147
He's Making bracket kits right now.
Should be available soon.
Poles you have to make yourself.
TURBS
04-17-2015, 12:42 PM
#1148
See post 1242
04-17-2015, 01:28 PM
#1149
Down to 3 kits until I can get more made, which will take at least a week or more to get the nuts, bolts, hitch pins, rivets and brackets cut, formed drilled, bead blasted, etc.
OC - are you planning on making any more pole kits when you get back from FL next year?
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
04-17-2015, 01:52 PM
#1150
Senior Member - Retired
Thanks TURBS
See if this helps.
Lowe's Home Improvement
Attachment 74496
TURBS
TURBS
The additional information helps. Making my material list then off the Home Depot. I hope to also locate paint that is close enough to my dark browning awning arms so I can paint the brackets. Plan to drill the awning arm so I can add the second SS bolt to each bracket.
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
04-17-2015, 02:01 PM
#1151
NOTICE: All those that ordered the kits will not get the (2) 1/4 x 3/4 bolts & nuts as those will be in the new kits available maybe tomorrow instead of Tues. All the hardware came in this morning and TOWTA jumped right on the kits. I just have to finish bead blasting the upper brackets.
04-17-2015, 02:03 PM
#1152
Depends on the price of the tubing. It keeps going up and I think the price of the entire pole assy is reaching its limit.
04-17-2015, 02:38 PM
#1153
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
I used two of these paint extension poles from Home Depot for my awning poles...mounted the pole upside down with the fiberglass end at the bracket....the adjustable end had a quick release locking device with increments every 6 inches and I drilled some extra holes every 2 inches.....I then went to the PVC department and for the foot piece, I started with a 2X3 floor drain turned upside down, added a reducer, and then a 1/2" female threaded coupler, glued together......simply screw this on the end of the pole to stabilize it on the ground
Wooster 4 ft.- 8 ft. Sherlock Extension Pole-00R0550000 - The Home Depot
Everything worked great....really like the way they stow away for travel...I will unscrew the foot piece for travel......thanks OC for the bracket kit....a mod that I know we'll use very often.
Lloyd & Kathy Martin
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014-38nights/3500 mi; 2015-66nights/6260 mi;2016-44 nights/6106 mi;2017-65nights/6992 mi;2018-47nights/7376mi;2019-65nights/7825 mi;2020-59nights/4142mi;2021-39nights/3072 mi;2022-59-nights/6149 mi;2023-36nights/3001miles.
04-17-2015, 03:00 PM
#1154
Originally Posted by jtownstumpjumper
Funny, I used one of those very poles for version 1 of my home built stabilizer. Worked pretty good but had a little too much play in it and I'm re-engineering it for one that is more rock solid. I may be a little picky and could leave it alone but isn't that what moding is all about? Achieving personal satisfaction of the job well done perfectly..
04-17-2015, 05:20 PM
#1155
Oc the sunshade fits wonderful !
I even had a model!
TURBS
04-17-2015, 05:27 PM
#1156
Still can't quite take the snow blade off the pick up yet?
#1157
Nope.
TURBS
04-17-2015, 05:31 PM
#1158
Nope.
TURBS
71 and cloudy here with rain expected. We are 8" of rainfall ahead of what we had last year at this time.
04-17-2015, 05:32 PM
#1159
79 and sunny @ 532pm
TURBS
04-17-2015, 07:31 PM
#1160
TURBS,
I wondered what the orange curved thing was. Then I decided it might be one of those rare snow clearing blades affixed to the front of tractors and trucks. Never see them out here in Southern California. Not much snow when the weather is bright, clear and in the low 80's. Unfortunately we do not see much water either.
2013 Smart Car TOAD
