Old 09-06-2014, 01:09 PM   #701
PSUFan1's Avatar
Originally Posted by OldCoot View Post
Here you go.
That's a great pic. Where do you find that top piece on the PVC pipe that holds the awning? Is that something you can get at lowes?
Tim & Tracy, Jennifer (15), Alyssa (10), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 09-06-2014, 01:10 PM   #702
[QUOTE=Big Paul;695891]
Originally Posted by Klemintine View Post
...Unless they are different from the ones i have for a manual awning they will mot work with OC's brackets. But you can make some brackets similar to his that will work. I decided against that and used painters poles. Might look better painted white but so far the tan color is just fine with me. I just need to cut them off about 8" to be even with the electric awning poles.
I think he is talking about using the small HORIZONTAL "C" channel arms at the top of the awning, not the large legs that connect to the bottom of the trailer and the end of the awning tube.
Old 09-06-2014, 01:19 PM   #703
It looks like it is a T that has been modified. Never used that type pole as I didn't want something else to have to store.
Old 09-06-2014, 09:58 PM   #704
Kits are going pretty quickly now.
Old 09-06-2014, 10:26 PM   #705
NELA
Weezer's Avatar
I saw a video a bit ago where they called that a "saddle" fitting, and they found it at Lowe's.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 09-06-2014, 11:17 PM   #706
PM sent
Steve
4x4FF is offline   Reply With Quote
Old 09-07-2014, 08:32 AM   #707
offroad's Avatar
I'm going to use either PVC or metal conduit for my poles. Want to paint them to match the RV regardless.
Should either type be primed before painting, or just rough up with a Scotch Brite pad then paint?
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 09-07-2014, 09:23 AM   #708
TURBS's Avatar
pvc ones need adhesive promoter before being painted.
TURBS
"SABRE OWNERS UNITED"
Old 09-07-2014, 09:29 AM   #709
Both the electrical PVC and the metal electrical conduit need primer from what I've been told. Scotch Brite pads will help scuff the finish before primer and painting.
Old 09-08-2014, 06:56 PM   #710
Only 13 sets left. Pm me for details.
awning, modifications
