Old 11-14-2014, 11:37 AM   #821
TURBS's Avatar
Originally Posted by 4x4FF View Post
Oc,
When you make poles, what material do you use?
Steve
He uses aluminum.
Many of us have also made them from galvanized conduit as well.
TURBS.
Old 11-14-2014, 11:54 AM   #822
Oc,
Steve
Approximately 0.105" wall alum tubing.
Old 11-14-2014, 11:59 AM   #823
Thanks. Don't mistake my comment with dogging your brackets. They actually work great. The site I'm at slopes and I have my poles at full extension so that is probably part of it.
Steve
4x4FF is offline   Reply With Quote
Old 11-14-2014, 12:09 PM   #824
Thanks. Don't mistake my comment with dogging your brackets. They actually work great. The site I'm at slopes and I have my poles at full extension so that is probably part of it. Steve
Not a problem, every thing has it's limits.
Old 11-14-2014, 01:07 PM   #825
BamaBob's Avatar
Hi all,
Finally got OC's brackets installed and so far the idea is terrific. The only problem I am encountering is using the 1-1/4" and 1" PVC electrical conduit for the legs. They don't seem real strong, in fact the tend to bend quite a bit especially when I snug the ratchet strap up. Has anyone else experienced this?? I'm sure if I used metal it would be better.
Steve
We used a set of painters extension poles from Lowes. Cut off the plastic on both ends, capped them with copper end caps and drilled a couple of d-clip holes to secure the poles in the event of a "real" storm (normally, they "twist" to tighten and so far that has worked just fine for us - the holes are a insurance policy though)
They work great, look great (I painted them to match our rig) IMHO the only thing better are the "origional" poles OC was making (I *just* missed out on getting myself a set of those )
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 11-15-2014, 09:28 AM   #826
Phat Phrog Stunt Crew
elind's Avatar
Before you cut off the threaded end of the painter pole try screwing on a painter pad. Makes for a great base to set on your patio mat with out punching holes in it.
2014 Wildcat 327ck
2015 129 nites
2016 63 nites
elind is offline   Reply With Quote
Old 11-15-2014, 09:34 AM   #827
BombDoc's Avatar
Hi all,
Steve
I've had the electrical conduit support poles for at least 18 months. I have used them very often. I have found them to be very supportive with minimal flex. I recently used them at a very windy tailgate event and no one else around me could deploy their awning. If I over tighten them, I can see some flex, but they have done a great job protecting the awning from bouncing around.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-0
BombDoc is offline   Reply With Quote
Old 11-16-2014, 06:39 AM   #828
leencharlotte's Avatar
So far, not enough folks willing to come to Concord to pick them up and I need to buy material for at least 10 sets to get the supplier to order and cut the tubing. I might even make some in FL if anyone wants to come to the Kissimmee area to pick them up.
Just a reminder I will pick some up from you if you make them.. Only 45 min away
2011 Ford F350 SRW
2014 Sandpiper 365SAQB
2011 F-350 SRW Lariat FX4
leencharlotte is offline   Reply With Quote
Old 11-17-2014, 05:39 PM   #829
Not too late to get a kit for a stocking stuffer for Christmas. Use as a subtle hint to DH that you want him to make you a set of poles so you can leave the awning out and not have to run it in every time a gust of wind comes along.
Old 11-19-2014, 12:12 PM   #830
textman's Avatar
I'll drive to pick up a set of poles!
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded w/EGR Delete
Loving Life
textman is offline   Reply With Quote
awning, modifications
