Old 02-16-2015, 09:56 PM   #881
CANADA FROG RALLY 2017
B and B's Avatar
I figured you were home OC. The forum has not been the same place with the lack of your insight, professionalism, knowledge and annoying Turbs
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
Old 02-16-2015, 10:02 PM   #882
Witch Doctor's Avatar
Originally Posted by OldCoot View Post
Got the 20 outer tube pads cut, de-burred and ready to weld and the positioning fixture made, outer tubes de-burred on both ends. Will de-burr the 20 inner tubes tomorrow, layout, drill and chamfer the 28 holes in each pole. Will wait until better weather to take the pads over to Butlerbuilt to get them welded.
well you didn't waist any time did you. It's snowing here, first time this year 19 degrees. Getting tired of WINTER. You still have 10 sets of brackets or do you have to make them to?
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 02-16-2015, 10:11 PM   #883
B and B's Avatar
First time snowing.. We have 4 feet Glen. Broke the all time temp record last night, coldest ever at -35 C.
I bet OC was missing the shop being south all winter!!
B and B
Old 02-17-2015, 02:03 AM   #884
Phat Phrog Stunt Crew
elind's Avatar
I seen the Nashville Father/Son Love has started for the season.
2014 Wildcat 327ck
2015 129 nites
2016 63 nites
elind is offline   Reply With Quote
Old 02-17-2015, 07:56 AM   #885
TURBS's Avatar
I think when "Phil" sees his shadow "and he did" oc should stay in florida for 6 more weeks.........
Old 02-17-2015, 08:04 AM   #886
well you didn't waste any time did you? It's snowing here, first time this year 19 degrees. Getting tired of WINTER. You still have 10 sets of brackets or do you have to make them to?
Have brackets for the 10 sets and a few bracket kits left over. Also have enough material left to make 25 more sets of brackets.
Old 02-17-2015, 09:54 AM   #887
9 sets of brackets left for those that don't get a set of the 10 awning poles.
Old 02-17-2015, 02:42 PM   #888
After threatening TOWTA, she finally got motivated and got the 640 holes laid out, center punched, drilled, chamfered and de-burred. So all that is left to do is get the outer pole pads welded and riveted on. If I'm lucky, she should finish the 10 sets by the weekend.
Old 02-17-2015, 02:58 PM   #889
TURBS's Avatar
After threating TOWTA, she finally got motivated and got the 640 holes laid out, center punched, drilled, chamfered and de-burred. So all that is left to do is get the outer pole pads welded and riveted on. If I'm lucky, she should finish the 10 sets by the weekend.
Ship me a set when your done would ya.
Send timmy a set to.
Old 02-17-2015, 03:31 PM   #890
You know that will happen just as soon as a thin layer of ice forms in H***!
awning, modifications
