Old 02-25-2015, 10:50 PM   #951
Would you guys from the St. Louis area be able to pick up one additional set?
Steve
4x4FF is offline   Reply With Quote
Old 02-25-2015, 11:07 PM   #952
4 sets of poles left
8 sets of brackets left
Old 02-25-2015, 11:11 PM   #953
Do you still Mail them?
mb2011 is offline   Reply With Quote
Old 02-25-2015, 11:12 PM   #954
ONLY the bracket kits NOT THE POLES.
Old 02-25-2015, 11:20 PM   #955
mike618's Avatar
Steve
I'm picking mine up in May, if you want I could haul another set home with me. You will have to pay Old Coot for them now so that he will hold it till then.
Mike and Mary
2014 Flagstaff 831RKBSS
2001 Suburban 2500/6.0
1999 Chevy 2500/6.0
mike618 is offline   Reply With Quote
Old 02-26-2015, 04:16 PM   #956
member
Does anyone else have just one bolt on the top of the awning to bolt the top bracket to ? if so how did you attach it did you drill another hole and put another nut and bolt or is one enough?
2016 Rockwood 8310SS signature ultra light
2015 F150 3.5 ecoboost max tow pkg.
HIDE OUT is offline   Reply With Quote
Old 02-26-2015, 04:24 PM   #957
Kaadk's Avatar
I only have the one. I really 'should' put a second one in, since the bracket doesn't stay flush with just one, but so far it's held up through a couple of heavy storms with just that one bolt.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 02-26-2015, 04:29 PM   #958
Herk7769's Avatar
I also only have one (been about 2 years like that), however will be adding the second one this spring. I think not having the second one allows some small movement of the arms when the legs are folded and retracting or extending the awning. This causes some creepage of the awning material in the track and eventual failure of the arms to close completely when folded.
HAM CALLSIGN - KC3FFW
Old 02-26-2015, 04:29 PM   #959
Brother Les's Avatar
Drill a hole in the arm and put a same size bolt with a lock nut on it. The one bolt goes into the cross arm and could cause some wobble in the threads. The new bolt will add more stability to the bracket and pole and take pressure off of the threaded bolt
Brother Les
Old 02-26-2015, 04:32 PM   #960
IlliniJoe's Avatar
I only had one bolt also, so that is all I used at the time. I will drill and add a second one later and will add the poles and pole bracket then also.
Retired Army CW4 - "Waterborne"
2005 Chevy 2500 crew cab with Duramax/Allison
2014 Lacrosse 327RES
Days camped 2014 - 0, 2015 - 24
IlliniJoe is offline   Reply With Quote
awning, modifications
