09-05-2014, 01:07 PM
#661
Originally Posted by Weezer
...Now ya buy his brackets and make your own poles, some folks use painter poles. Some folks use cargo bars...
And some use ELECTRICAL PVC with a cost of less than $15, 2 10' lengths of 1" and 1 10' length of 1-1/4" with the bell cut off and then cut in 2 equal pcs of approx. 58.5" instead of the 60" specified on the dwg. Heat about 3" of the 1" with a heat gun or hair dryer and put in a vise and close to 1". Cut to the lengths specified and drill your holes per print obtained in the FRF Library.
Forest River Forums - Downloads - Awning - New Updated DWG of the Poles
09-05-2014, 01:15 PM
#662
I used electrical conduit.
TURBS
"SABRE OWNERS UNITED"
09-05-2014, 01:22 PM
#663
Hands down the most cost effective and lightest weight. Painters poles will run you 5 times that and tack on another couple of pounds. I went the painter pole route just because I'm lazy and they look cool, but the PVC's will provide more than ample strength.
09-05-2014, 01:25 PM
#664
Ten bucks for metal conduit.
And you can make two sets![emoji12]
TURBS
09-05-2014, 01:37 PM
#665
Nice! Don't those weight quite a bit more?
I guess if my main focus was "cost effective" I would have never bought a TT to begin with.
Everyone together now.. "money pit".
09-05-2014, 01:45 PM
#666
Yep. RV'ing is not cheap. In many ways it is the "lifestyles of the rich and famous".
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
09-05-2014, 01:46 PM
#667
I guess if my main focus was "cost effective" I would have never bought a TT to begin with. Everyone together now.. "money pit".
Don't know about wt difference, but the pvc poles don't rust.
09-05-2014, 02:09 PM
#668
Yarome,
You're tryin' to "squirrel" 'em.....trust me, it won't work.....for long.
Can't blame a feller for tryin. Been stuck with a gas stove at the house for going on 4 weeks and it's just snuffin the life outta me.
09-05-2014, 02:36 PM
#669
Same sizes?
(2 10' lengths of 1" and 1 10' length of 1-1/4")
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
09-05-2014, 03:00 PM
#670
Neither does galvanized metal.
Geeeze
TURBS
09-05-2014, 03:01 PM
#671
Originally Posted by offroad
Same sizes?
1/2 and 3/4
TURBS
09-05-2014, 03:04 PM
#672
Geeeze TURBS.
Sure does when you drill holes in it and cut it. Geeeze!
09-05-2014, 03:06 PM
#673
Not after you prime and paint.
Good thing your not my neighbor.
TURBS
09-05-2014, 03:09 PM
#674
Not after you prime and paint. Good thing your not my neighbor. TURBS
And the first time you insert the pins the paint/primer is gone. Your neighbors don't even want to be you neighbor.
PVC poles don't need the paint/primer to keep from rusting. GEEEZE!
09-05-2014, 03:24 PM
#675
What is the reason you heat and close 3" of the end of the smaller tube to 1"? Fit inside one of the brackets?
09-05-2014, 03:27 PM
#676
Mine must me special then.
No rust.
TURBS
09-05-2014, 03:31 PM
#677
Yes, you are correct, so it will fit in the upper brackets.
09-05-2014, 04:23 PM
#678
No rust.
TURBS
Your wasting your breath, Only one way to do things and that's OC'S no matter what anyone says. I said it was your turn in the barrel......
Coachmen M/H
Concord
2018 / 300 DSC
09-05-2014, 04:27 PM
#679
NELA
You two....gettin' catty.
Gonna have to put you in separate corners?
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
#680
That's alright
Over time aluminum dulls and will oxidize and pvc will fade and get brittle
TURBS
