04-01-2015, 11:43 AM
#1061
Originally Posted by bob caldwell
Senior discount....brother-in-law deal......secret hand-shake!!! Drone, pony express, snail mail??
USPS Priority Mail, no discounts!
04-01-2015, 05:03 PM
#1062
Left Coast
I see.....now their collector items, soon to be seen on Roadshow.
04-01-2015, 05:05 PM
#1063
Oc or the brackets? [emoji12]
TURBS
08 duramax tuned n modded, 32bhok Sabre
04-01-2015, 05:07 PM
#1064
Left Coast
TURBS
Either/or
04-03-2015, 01:12 PM
#1065
Originally Posted by Mrs Evans
Did you get the poles from OC too? If not, where did you get them?
At first I just got the brackets from OC and I followed his instructions to use PVC electrical conduit to construct the poles. It isn't hard to do, and I tried hard to drill the holes straight but the finished result looked like I had my eyes closed. They were functional but ugly. When I saw he was back in the pole business I placed an order. They look so much better than the pair I made, and now when I see them I smile instead of cringe.
I live with fear every day, and sometimes she lets me go fishing.
2019 Surveyor 251RKS
2008 Ford Expedition EL
04-06-2015, 08:40 AM
#1066
Pole end detail
Originally Posted by ChibullsAN
Yep. I use these. I drilled extra holes every 2". Gets better adjustment resolution. I removed the acme style screw end part ( for the paint roller) and machined my own new end piece to attach to the brackets I made. You can always just drill a cross hole through that cast threaded piece on the end of the pole instead.
I too have the painters poles from HD and plan to order a set of brackets from OldCoot. I have a few questions if you don't mind.
Can you post a picture of the special end you machined?
Do you leave the poles attached when you travel? Is that working OK?
Are the lower brackets sized OK for those poles?
As an experiment, I picked up a decent paint rolled and cut off the handle to get a socket so I had something to screw the pole into. But then I would probably want to unscrew the poles while traveling (roller handle is only plastic) and stow them in the pass through. Keeping them attached would be better as long as they fit into the lower bracket and don't bounce around.
What type of foot do you use on your painters pole?
I am working with the idea to fit a PVC female to 3/4 inch pipe thread adapter and a pipe floor flange. Gives about a 4 inch dia. foot. I could add more surface area if needed. I also saw somewhere a plastic floor flange. Do you think the foot needs to be physically attached to the pole?
Still working out the details so all information is helpful and appreciated.
Thanks,
2015 Roo 23IKSS
2016 F150 SuperCrew 3.5 EcoBoost
04-06-2015, 09:35 AM
#1067
Used the painters polls from Lowe's or HD, cut the tip off the screw into handle part and left the plug for support drilled hole thru it for attachment to top. Drilled holes in plastic handle for drainage. Used them while in FL for two months in 20 to 30 mph winds with out any problems without cross pins.
04-06-2015, 09:55 AM
#1068
Awning pole hold down kit
Thanks,
Here's a picture of how I went about attaching poles with a "foot"... I didn't want to deal with straps. I used OC's upper brackets, but I remove them (the poles, not the brackets) for travel.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
04-06-2015, 09:58 AM
#1069
Phat Phrog Stunt Crew
I got a set of painter poles from Lowes (4'-8' @ $10.98) and hung it with the hole of the plastic handle. I then used a small paint pad screwed in the other end for my base. It is big enough to set on beach sand or a patio mat without poking holes through it.
2014 Wildcat 327ck
04-06-2015, 10:09 AM
#1070
May I ask why you don't stow them on the awning for travel? That was the whole idea of the bracket design.
04-06-2015, 10:13 AM
#1071
Left Coast
Attachment 73225
The straps are for winds that normally us electric awning folk would re-tract our awnings for. Really depends on if you can camp in sheltered areas or not. Gets expensive if they turn inside out. The 'doggie' corkscrew anchors work really good for straps and a small board or paver stone for soft ground also works.
04-06-2015, 10:20 AM
#1072
Wifey said she didn't like it... looks ugly. I don't question those kinds of things. 😏
04-06-2015, 10:24 AM
#1073
If you notice my picture... I have floor flanges at the base of mine, attached to the poles... Then use HD tent stakes to anchor into the ground. Works very well in windy conditions.. And nothing for the kids to trip over.
04-06-2015, 10:31 AM
#1074
Left Coast
I did notice, but maybe some people haven't accepted the concept yet.
04-06-2015, 11:45 AM
#1075
I was thinking the same thing. With a rigid pole why also use straps.
What kind of floor flanges are those and how do you attach them to the poles? Hard to see in the photos.
2015 Roo 23IKSS
04-06-2015, 11:50 AM
#1076
Left Coast
You'd find out if the wind came up... and not being close by. It's your choice.
04-06-2015, 11:54 AM
#1077
If there painted the same as the awning arm they "appear" like oem equipment.
TURBS
2015 camping "2 nights"
04-06-2015, 11:55 AM
#1078
I was thinking the same thing. With a rigid pole why also use straps. What kind of floor flanges are those and how do you attach them to the poles? Hard to see in the photos. Thanks
As soon as the wind picks up and pulls the pad stakes and throws the whole awning back over the trailer, you'll have wished you had used the ratchet straps and dog screws.
04-06-2015, 12:13 PM
#1079
What he said [emoji651] [emoji651] [emoji651] [emoji651]
TURBS
04-06-2015, 12:23 PM
#1080
so nice to see TURBS and Old Coot getting along. Must be residual effect of a holiday
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
