Old 07-17-2015, 01:04 PM   #1541
Originally Posted by dannyabear View Post
OC, sorry to hijack but would you post pic again of wood clothes rack?
Here ya go.
Name:	TOWTA's New Laundry Board.jpg
Old 07-17-2015, 04:01 PM   #1542
Pictures of new lower stow bracket installed
Red Wolf has requested a picture of the new lower stow brackets installed on their awning. Would someone kindly post some?
Old 07-17-2015, 04:02 PM   #1543
TURBS's Avatar
Hope he's not trying to mount the lowers before his poles get to him? [emoji12]
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 07-17-2015, 04:07 PM   #1544
Tucson Joe's Avatar
TURBS, I mounted my lowers before I will get my poles. I hope that is not to much of a problem?
2014 Ford F450 4+4
2009 XLR 40X12
2009 RZR ready for the trail
2014 RZR XP 1000
Days Camped in '18- 106
Days Camped in ‘19- 23
Tucson Joe is offline   Reply With Quote
Old 07-17-2015, 04:09 PM   #1545
TURBS's Avatar
Originally Posted by Tucson Joe View Post
TURBS, I mounted my lowers before I will get my pols. I hope that is not yo much of a problem?
The lower brackets line up with the lower holes on the poles.
No way to know where the holes will be till the poles are in hand.
TURBS
2011 32bhok Sabre
Old 07-17-2015, 04:10 PM   #1546
TURBS's Avatar
The lower bracket pins into the poles to lock the poles.
TURBS
2011 32bhok Sabre
Old 07-17-2015, 04:12 PM   #1547
Tucson Joe's Avatar
If I am off, can I drill a new hole in the pole? Just a thought?
2014 Ford F450 4+4
2009 XLR 40X12
2014 RZR XP 1000
Old 07-17-2015, 04:12 PM   #1548
TURBS
2011 32bhok Sabre
I don't know, but it shouldn't make any difference. The lower brackets should be centered on the arm and flush with the bottom of the alum or within 1/4" of the bottom. Once the brackets are installed, all that is required is letting the pole swing into the bracket and using the bracket as a template, drill the 9/32" hole completely thru the pole.
Old 07-17-2015, 04:14 PM   #1549
TURBS's Avatar
You'd have to drill a hole in each pole all the way thru and straight "upper and lower" and they have to line up in order to get the pin in.
You'd be better off moving lowers to match poles .
TURBS
2011 32bhok Sabre
Old 07-17-2015, 04:16 PM   #1550
TURBS's Avatar
Have to drill thru both poles and straight thru.
If holes are off the pin won't go thru straight.
Or at all.
TURBS
2011 32bhok Sabre
Old 07-17-2015, 04:19 PM   #1551
TURBS's Avatar
Lol besides that both people asking have pretty white powder coated poles coming to them!
TURBS
2011 32bhok Sabre
Old 07-17-2015, 04:25 PM   #1552
DK-in-SC's Avatar
Here you go...
Name:	ImageUploadedByForest River Forums1437168316.647157.jpg
I live with fear every day, and sometimes she lets me go fishing.
2019 Surveyor 251RKS
2008 Ford Expedition EL
DK-in-SC is offline   Reply With Quote
Old 07-17-2015, 04:25 PM   #1553
TURBS's Avatar
Joe, what's your c to c now on your upper and lower bracket holes?
TURBS
2011 32bhok Sabre
Old 07-17-2015, 04:33 PM   #1554
TURBS's Avatar
This was my original design with two pins.
Now I just require one pin.
But as you can see my upper doesn't go down near as far.
Now the lower sticks out only about an inch and you pin thru both poles.
TURBS
2011 32bhok Sabre
Old 07-17-2015, 04:37 PM   #1555
TURBS's Avatar
Shown here albeit upside down.
TURBS
2011 32bhok Sabre
Old 07-17-2015, 04:41 PM   #1556
TURBS's Avatar
Originally Posted by B and B View Post
Are their liability stickers available to attach if someone walks into a black powder coated pole and spills there beer??
I got dot reflective tape for that deal lol
TURBS
2011 32bhok Sabre
Old 07-17-2015, 04:45 PM   #1557
TURBS
2011 32bhok Sabre
His are mounted higher than mine, my brackets are 62-3/8" center to center.
Forgot, you mount yours upside down.
Old 07-17-2015, 04:49 PM   #1558
TURBS's Avatar
Mine are roughly 58- 7/16 c to c
Varies a 1/16 one way or the other so that's not gospel.
TURBS
2011 32bhok Sabre
Old 07-17-2015, 04:50 PM   #1559
TURBS's Avatar
Soooooooo if there mounted that low it will work.
Just pull inner pole out and use the lower hole in that.
You just won't be pinned thru both poles.
TURBS
2011 32bhok Sabre
Old 07-17-2015, 04:51 PM   #1560
TURBS's Avatar
Right?
TURBS
2011 32bhok Sabre
awning, modifications
