Old 12-07-2017, 08:28 AM   #1
CURT 17120 Weight Distribution Shank rise 7 3/4", drop 9 3/4"
This shank provides much more rise/drop than the standard WDH shank.
North Houston Pick up only $40
Curt's Description
At CURT, we think your towing equipment should never be the limiting factor. If your trailer has the tonnage and your truck has the muscle, then nothing should stand in the way of you hitching up and heading out.Made with high-strength steel and a solid design, this CURT WD replacement shank is made for heavy-duty towing. It features a 2" x 2" shank to fit any equivalent size receiver tube opening, and it offers the strength necessary for towing large RVs and travel trailers. While the receiver tube shank measures 2" x 2", the vertical shank offers a universal fit to be compatible with most CURT weight distribution hitches. Holes in the vertical shank are spaced 1 1/4" center-to-center and have a 3/4" diameter, allowing for a maximum rise of 7 3/4" and a maximum drop of 9 3/4". To make sure this weight distribution hitch accessory has the grit to stand up to whatever the road throws at you, it comes finished in a durable black powder coat finish.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition
2018 Chaparral 360IBL w/Andersen Ultimate 2, Tireminder SMART TPMS, Swift Hitch SH04 WiFi Backup/Rear View Camera, Progressive EMS-HW50C
Prior Rig: 2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is online now
weight
