04-23-2013, 05:08 PM
#61
Originally Posted by RodeoGeorge
I just painted set #1. Hate those drying times. LOL
Going to completely install the first set, and see what I learn in the process.
I am changing out the upper mounting bolt to one with a shank to reduce the threads wearing on the pivoting mount.
RodeoGeorge
Don't think the threads would wear the mount, but I do understand the concern. Thought of using longer bolts, but didn't want to have to cut all the bolts off to get rid of the extra threads.
04-23-2013, 05:18 PM
#62
An appropriate sized shank bolt is a good idea tho !
04-23-2013, 05:23 PM
#63
Hard to find, if at all, in stainless and wouldn't want to use anything but stainless..
04-23-2013, 05:26 PM
#64
Boat loads at ace hardware, as I got some today phor a project and in ss !
And they were Allen head to.
04-23-2013, 05:34 PM
#65
Denver, CO
I think you should still make the top brackets... How hard could that be. The rest do the pieces can be had commercially, like I did. The top brackets are the key... AND THEY LOOK COOL.
2017 Fuse 23T
04-24-2013, 05:37 AM
#66
Do a search and Find your local "Fastenal Company"... If its a stainless shoulder bolt your looking for... Or anything else that's a fastener, if its made, they have it.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
04-24-2013, 06:26 AM
#67
RodeoGeorge
Bronze shoulder bushings would also reduce the wear on the shanks. These are awning tie down poles and as designed will outlast the awning and probably the trailer. Whomever wants to re-design and manufacture them, have fun!
04-24-2013, 06:28 AM
#68
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-24-2013, 06:31 AM
#69
That's the most labor intensive task in the whole project. Layout, drill, cut out, file, form and bead blast. If I had a powered hyd. press, cutout dies, etc. it would be easy, but I only have a small garage with hand tools, not a complete machine shop with manufacturing equipment.
04-24-2013, 06:35 AM
#70
Originally Posted by herk7769
Like it Herk! Helps if you just look where you're going too!
04-24-2013, 09:14 AM
#71
Always Learning
Hmm. Now you have me thinking. For my kayaks, I use retro-reflective ropes. They really pop when a light is shined on them. (Assuming lights are used, of course.)
04-24-2013, 11:38 AM
#72
Denver, CO
Oh darn, maybe thats why they look so cool.
2017 Fuse 23T
04-24-2013, 11:46 AM
#73
Original one I fabricated was a pc of 1" wide alum with the ears tig welded on. Then made a flat layout and hand formed the 2 ears in a vice and finally built the crude form die & punch to form the 2 ears and the angle for the ratchet straps in my hyd. arbor press.
04-24-2013, 11:57 AM
#74
Still time to make the UPS pickup.
04-24-2013, 12:09 PM
#75
Denver, CO
Original one I fabricated was a pc of 1" wide alum with the ears tig welded on. The made a flat layout and hand formed the 2 ears in a vice and finally built the crude form die & punch to form the 2 ears and the angle for the ratchet straps in my hyd. arbor press.
Yes they are AWESOME brackets. I am SO glad I got them from you before you quit doing them. It's also a great design and overall super idea.
2017 Fuse 23T
04-24-2013, 01:44 PM
#76
Hey btw OC I got the upper brackets in my little care package way back when, but no lowers to store.
I guess I didn't make enough sales
04-24-2013, 01:51 PM
#77
Sorry about that, figured you'd use duct tape til you got a pc of 1" alum strap to make them out of. OH, BTW, you DO have to have poles MOUNTED before you need the stow brackets just in case you forgot.
p.s. Use duct tape, I'll bring a set to Goshen for you.
04-24-2013, 01:53 PM
#78
Worked on it yesterday.
I might have something concrete by August 3rd but don't count on it.
04-24-2013, 01:56 PM
#79
Kinda heavy if you're using concrete. I'd suggest a pc of re-rod in the center and definitely an extra bolt in the attaching bracket.
04-24-2013, 05:40 PM
#80
Owner/Operator
Here's a tip I learned after the first support.
If you're going to drill the second hole for the upper mounting bracket, install the bracket and the support, center the lower portion of the support on the awning arm, mark the location for the second hole, and then drill it.
On the first one I eyeballed whether the upper bracket was "straight", and I was off slightly. But slightly at the top can become quite a bit at the bottom. LOL
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
https://www.forestriverforums.com/for...ons-36212.html
